mondeo v6 engine question
Old Oct 12, 2010 | 12:10 PM
3dr cossie's Avatar
3dr cossie
Default mondeo v6 engine question
my st200 has developed a noise and it sounds like it is coming from a pulley. if you look from the drivers side of the engine its the pulley at the top inbetween the V. what does this pulley drive?
the car has recently had a new alternator, idler pulley, belt tensioner and belt, so these parts should be good.
any help would be good
cheers Matthew
Old Oct 12, 2010 | 12:14 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
cheers Matthew
What kind of noise? A ticking, or a 'thrumming'?
Old Oct 12, 2010 | 12:18 PM
Neil S's Avatar
Neil S
That pulley is the PAS pump
Old Oct 12, 2010 | 12:44 PM
The Youth.'s Avatar
The Youth.
hope it's not the timing chain tensioner thats noisey, my st200 started making a noise, a few miles later the pistons exited the block!!!
the engine blew 7 miles after I sold it pmsl!!
steve
Old Oct 12, 2010 | 03:45 PM
cjwood555's Avatar
cjwood555
Mine does the same. Check PAS fluid level. Mine was v low. Topped up. No more noise. Job jobbed. (temporarily lol!)
Old Oct 12, 2010 | 05:38 PM
3dr cossie's Avatar
3dr cossie
it sounds more like a worn out thrumming/squeaking noise, i'll check the fluid levels,
cheers for the help
Matthew
Old Oct 12, 2010 | 05:50 PM
Take the aux belt off and see if the noise is still there.
Old Oct 12, 2010 | 06:43 PM
Ridgey's Avatar
Ridgey
As said top pulley is PAS.
Mine has a soft ticking noise when hot from that area.
I don't think it is the auxilary belt, but can't make out if it is the chains or chain tensioner. Put it this way i ain't taking the whole bloody engine apart to look at the chains. Major major job.
Unfortunately the car will be driven until it dies .
Old Oct 12, 2010 | 09:32 PM
3dr cossie's Avatar
3dr cossie
mine does it as soon as the engine is running,so temp is not affecting it,definitley sounds like a pulley issue,its going in the garage tomorrow so hopefully will find out what it is
cheers fo rthe advice
Matthew
Old Oct 12, 2010 | 09:59 PM
LHD220Turbo's Avatar
LHD220Turbo
i looked at a mondeo a few months back; weird kinda noise, turned out to be head gasket!
JoeyBoyden
Jan 4, 2024 02:36 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
