Mondeo Standard V6 to ST24 / ST200 ?
Somehow I have ended up with a Mondeo 2.5 V6 Ghia X which I might use as a cheapo track toy and/or run about.
Just need a simple answer really, apart from the obvious engine managment changes, what is needed to get these to ST24 power levels by exchanging parts or is it a waste of time ?
I know nothing about these engines and assume they are pretty much the same so any help appreciated
Unless you get a bargain that little lot will work out to be several hundred quid and a lot of aggro.
Yep, about 160odd bhp. Fit ST200 bits for an extra 20-30 or so bhp - Upper and lower inlet manifolds, cams, throttle body and air filter assembly. A remap would then be a wise idea.
Cheers Dan.
The car cost me £250.
Its in fairly good condition except the exhaust and brakes and all the toys work !!
I will get some prices and see if its worth it.
Tell you what, how about a feature where you fund the mods...
How about bolting a T4 and a set of bigger injectors to it and see how much power we can make before it shits itself..LOL
God I miss my cossie
I had a mk1 Mondeo ghia estate and it went really well,I loved the motor.
Tbh mate if it's a track tool or daily I really wouldn't bother for the additional expense.as it's a ghia x there'll be tons of crap you can remove to save weight and perhaps an exhaust/filter little remap and you'll have a tasty old tool.
Yeah just been looking under the bonnet and it looks like a proper chore to change.
Cant be much worse than doing a 4x4 cossie engine out without an engine hoist as I have done that many times..LOL
