Cheapest heat..... electric heater or Portable gas fire
as title, for my office which is only small, a oil filled radiator or fan heater or alike or a portable gas heater? Which is cheaper?
oil filled rad danny, calor gas stink and make condensation and if the gas bottle runs out your cold, get the biggest oil filled rad yo can, there thermostatic and you don't have to run it flat out, I use 1 in my living room when its not quite cold enough to have the central heating on
Most of the heaters have a cost per hour in the info! Oil filled are cheapest but typically produce the less heat. I think the cheapest but most efficient are the infa red ones, but it's a very direct heat!!
If your using an electric fire you might aswell burn £10 notes. The oil filled rad is the way forward. That calor gas fires are fuckin dangerous. I'm sure they tried to ban em a few years back
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
