Gearbox question..
Old Jan 25, 2005 | 08:07 PM
Stoo's Avatar
Stoo
Default Gearbox question..
Had this posted in the main area but as usuall get no serious(Or even answers at all)in there.So..
Box sound's and drives fine with no crunching or whining ect...except when,for example:
Driving along comming up to junction so changed down to 2nd,release clutch and as the rev's drop down when they get to about 1.5-2k there is a terrible transmission noise.Sure its the gearbox sounds really loud and high pitched
So,ive been told its the diff bearings are worn and need a new box.Right or wrong?
Just in case it could be something else rather than change the box and still have this problem
Thanks
Old Jan 26, 2005 | 01:24 PM
JesseT's Avatar
JesseT
Do you see anything strange in the speedometer when it does that, jitter perhaps?
Old Jan 26, 2005 | 04:19 PM
Moonie's Avatar
Moonie
The diff bearings can be replaced but it means splitting the box
Old Jan 26, 2005 | 05:24 PM
Stoo's Avatar
Stoo
Nope,nothing strange happens except the noise mate What if it did anyway?What would that mean as my old RST's speedo wiggled about at 30mph
Is splitting the box alot of hassle?Alot more than just changing it?
Thanks
Old Jan 26, 2005 | 07:25 PM
markyboy's Avatar
markyboy
ello matey
ive got exactly the same prob with mine and if u leave it much longer it wil progress to the other gears too as mine is doing it in 4th now
took it to a mech and he said its the diff bearings so its easier to get anew box than rather just replace them, a cost which im not looking forward too
Old Jan 26, 2005 | 07:31 PM
DRUE1's Avatar
DRUE1
Originally Posted by markyboy
ello matey
cost
Old Jan 26, 2005 | 07:54 PM
markyboy's Avatar
markyboy
about Ł350 for the box but that was a just a rough price i was given
Old Jan 26, 2005 | 08:09 PM
mrviper's Avatar
mrviper
go to the scrap yard and buy a diesel one for 40 quid and save up for a proper jobby
Old Jan 26, 2005 | 08:21 PM
rs_daz's Avatar
rs_daz
How long does a diesel one last?
Old Jan 26, 2005 | 08:28 PM
Stoo's Avatar
Stoo
Rather not go down a diesel box route.Apparently they are no stronger and have no LSD...
You can get RST box's for about Ł180 mate from a breakers Easy enough to change them it seems.Apart from the ABS belts
So how long did you get out it before getting worse?Is it drivable?Roughly in mile's
Old Jan 26, 2005 | 08:30 PM
Stoo's Avatar
Stoo
What Diesel box would fit anyway?Just any off a CVH Escort/Van?
Thanks
Old Jan 26, 2005 | 09:00 PM
SI-S1's Avatar
SI-S1
mine made that noise also when slowing down turned out to be main sharft bearing kept driveing mine and destroyed box wish i had got it fixed straight away now new bearings lot cheaper than new box.
Old Jan 26, 2005 | 09:01 PM
Stoo's Avatar
Stoo
How long did it last though mate?
Old Jan 26, 2005 | 09:23 PM
Moonie's Avatar
Moonie
Two of my gearboxes have done this and both times its been the main shaft bearing that has failed I dint drve with either box for long, as soon as i herd it was on its way out i got it back to work (did no more than 40 miles). Once the bearing has filed the main shaft stars to move about, this causes the gears not to mesh correctly which results in the teeth being damaged.
It impossible to say how long the box will last!
Old Jan 27, 2005 | 08:04 AM
JesseT's Avatar
JesseT
Worn diff bearings can be often diagnosed by a shaking speedo needle under torque. If it's the main shaft bearing, then the shaft is propably fucked too. This leaves at least these options:
Part with some cash and get a bullet proof box from Bernie.
Buy any used box and hope it lasts.
Buy a used box and swap the diff for the LSD form your old unit and while having the box open, change the bearings as well.
If the main shaft is not yet FUBAR, you can use a larger IB5 gearbox bearing with a separate inner race. This requires the casing to be machined sligghly and this can be done over here for around 50-100e. None of these conversions have yet broken down to my knowledge. (knock on wood)
There was a good topic on S2 gearbox repair some months ago. Try searching for it as it might help.
Old Jan 27, 2005 | 04:14 PM
Stoo's Avatar
Stoo
Nice one cheers guys!
Old Jan 27, 2005 | 07:57 PM
Moonie's Avatar
Moonie
The topic on rebuilding a S2 box in it the technical essay section
Old Jan 27, 2005 | 08:09 PM
chummer's Avatar
chummer
to be honest with u stoo , it sounds like there whining under strain!!! and rather than splitting the box , it's just as easy picking up a box for a ton!! swapping them over and at the same time uprate the clutch!
thats the route i would go!
good luck m8
Old Jan 27, 2005 | 08:13 PM
SI-S1's Avatar
SI-S1
my gearbox lasted about a month but depends on how its driven and milage
Old Jan 27, 2005 | 08:30 PM
MK5RST's Avatar
MK5RST
lol @ cvh diesel van, no, not a cvh box, a DIESEL box
Old Jan 27, 2005 | 10:15 PM
CarlRsT's Avatar
CarlRsT
How do you drive it ???? My mates on his 8th or 9th box
Old Jan 28, 2005 | 08:46 AM
markyboy's Avatar
markyboy
mines been making this noise for about 2 months now, it started off just doing it in 2nd gear but now its doing it 2nd,3rd and 4th
just take it easy
Old Jan 29, 2005 | 07:09 AM
Stoo's Avatar
Stoo
Cheers for all you help lad's!!
Old Jan 29, 2005 | 09:09 AM
rs_daz's Avatar
rs_daz
The box off a rs 2000 mk5 fits wiv abit of adjustment ive heard.
Old Jan 29, 2005 | 09:45 AM
NUTTIN RILLA's Avatar
NUTTIN RILLA
stoo thats what happened to mine as well, and as markyboy said it will progress into other gears, at the moment mines even doing it in 5th when im on the bypass and come of the gas
I had a gear box spare in my garage, so i sent it to a mob in glengarnock to get it reconed as im on my third box and would rather be safe than sorry
If i were you i would do the same cos you never no what someone is selling you till its in the car
Old Jan 29, 2005 | 04:52 PM
Stoo's Avatar
Stoo
Cheers Johnny mate
Dare i ask how much?And how long does it take them to get it back to you?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
