PF Plumbers?
Old Oct 11, 2010 | 04:04 PM
RichieST's Avatar
RichieST
Default PF Plumbers?
Hi all
Just wondering what a ballpark price would be to fit a power shower into a shower cubicle, that already has a standard gravity fed shower fitted? Water pressure is crap and would like something done about it!
Just looking for a very rough estimate of cost before I go thinking about it anymore!!!
Thanks
Rich
Old Oct 11, 2010 | 04:06 PM
fraser9764's Avatar
fraser9764
the biggest part of the job/cost would be the electrical supply i imagine? how close is it to your consumer unit? and easy of a run?
Old Oct 11, 2010 | 04:19 PM
TIFF's Avatar
TIFF
Chasing Radders
Are you asking for a "Pumped" shower or to get an Electric shower fitted.....
Some peoples idea of a power shower are very different??
By the sounds of it, as you all ready have a gravity shower fitted then fittiing a good pump to this should make a huge difference as long as the cold water feed tank to the hot water is big enough to cope
Old Oct 11, 2010 | 04:24 PM
dingla rs's Avatar
dingla rs
electric is the cost ,and you need change the cold from tank to mains nowt off a job as
can do that in the loft an blank hot ,so ur big bill will be for the sparky ,dont put a pump on, it will cost you same and will still be crap as im sure ul be on a small cylinder ,fit a good high rate elecy one
Old Oct 11, 2010 | 05:50 PM
St3V3_C's Avatar
St3V3_C
Something to consider with power shower (looks like electric shower, but has hot and cold feed, with built in pump) - they can be fookin noisey.
dovboy
23
Jun 20, 2008 09:59 PM
Christian and Beccy
13
May 6, 2006 09:50 PM
Fiecos Dan
May 1, 2006 08:25 PM
