Quick bit of building advice please...
Old Oct 11, 2010 | 08:09 AM
StephenC's Avatar
StephenC
..BS Motorsport..
Default Quick bit of building advice please...
Im wanting a removable fence post so gonna use one of them metal post mounts rawlbolted to floor so I can undo it and take it away to get car out. Im gonna dig hole and fill with concrete. Question is, to make it easier can I use http://www.wickes.co.uk/Postcrete/invt/221100 and smooth top over? Thinking about setting the bolts into it whilst its drying rather than drilling it after or would the bolts crack the concrete when tightened? Any help much appreciated.
thanks
Steve
Old Oct 11, 2010 | 08:29 AM
ben_frst's Avatar
ben_frst
you can use postcrete ive set bolts in it, i always thread them up through the post mount and put a nut ontop and whind them on until the bolt is flush in the nut it makes it easier when setting it in
oh and give it a day or two before you tighten them up the longer the better
Old Oct 11, 2010 | 09:04 AM
cjwood555's Avatar
cjwood555
Alternative is to just set bits of studding into the concrete, rather than anchor bolts....
Old Oct 11, 2010 | 09:22 AM
StephenC's Avatar
StephenC
..BS Motorsport..
good call, saves messing
Old Oct 11, 2010 | 09:33 AM
vaughant's Avatar
vaughant
Postcretes the bollox,always use it.
JoeyBoyden
Jan 4, 2024 02:36 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Tinshaw
Aug 4, 2015 09:16 PM
