Serial port question
Skint Passionford User
Evening folks,
I've just got a copy of VAGCOM to try and clear some of the bugs on my Golf, software installed nicely, but I cant plug the lead into my laptop!
Is there an adaptor available to plug this into a USB port at all? If not i'm stuffed
*edit* just looked on ebay and there fookin hundreds of them for £1.50
Next question, are they any good? ie will it work?
The cable for VAGCom is £250 odd from RossTech (Who make the software). There is variants of the cable about, but not guaranteed to work with the software. I bought a £5 USB to serial converter from EBAY, which didn't work with my Esc Cos autronics, but haven't tried with my Skoda's OBD II port yet.
Yes serial (RS232) is a old technology now (but very good) so it's getting faised out so any newish system won't have it the same applies for PS/2 and parallel ports.
You can get USB to serial connectors but have heard these cause problems as the software can not communicate properly as it's not a straight COM connection.
Martin
Martin
MOXA do good ones. We are a supplier for them but so are many others. http://www.moxa.com/product/UPort_1110.htm /
http://shop.mcidiventi.co.uk/product...639#googlebase
The main issue with some cheap ones is a lack of hardware buffers (important for large data transfers / streams). Some of them don't even implement the handshaking lines.
HTH
Chris
HTH
Chris
Chris
Chris
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
