mondeo/st170 brake upgrade help
Oct 10, 2010 | 07:36 PM
mk3 mondeo/st170 calipers is std the servo man enough?
what brake lines do i need?
tech drawings for spacer and what bolts do i buy?
Oct 10, 2010 | 08:08 PM
I have had st170 on mine for a few years, standard servo is fine and standard brake pipes with braided hoses works perfect
Oct 10, 2010 | 08:31 PM
sweet guess i'll fit that up tomorrow
Oct 11, 2010 | 09:21 PM
got my calipers now just gotta get disc and fitting kit any info is much appriciated
Oct 12, 2010 | 02:59 PM
Just use your std servo. Try to find the fitting kit from ebay. I bought mine for 13-14q and there are the spacers and the new bolts. You don't need to change your brake lines if they are in good working order. The only think you have to do is to drill the hub because the new bolts are M12 and the std M10... Is very very easy mod, don't worry!
Oct 12, 2010 | 03:02 PM
Oct 12, 2010 | 08:04 PM
good stuff dont seem to be any on there at the moment tho
su just drill and tap to m12?
Oct 12, 2010 | 09:33 PM
No tap, just drill, the threads are in the calipers not the hub
Oct 12, 2010 | 09:34 PM
Oct 13, 2010 | 06:02 AM
are you using mk3 mondeo callipers and discs? looking to do this as an alternative to cossie as there is many mondeos in scrappys. cheers
Oct 13, 2010 | 06:07 AM
No, Mondy calipers and pads, Focus ST 300mm discs,
Oct 13, 2010 | 07:58 AM
thinks its time for 1 of karlos's "for anybody intereted in......................."" guides
Oct 13, 2010 | 03:13 PM
Quote:
Originally Posted by
studabear
Do I do that many?!
lol
Oct 13, 2010 | 06:30 PM
There always a good read though
Oct 13, 2010 | 06:34 PM
Well if they help a few people out thats the main thing!
Oct 13, 2010 | 07:50 PM
if i get all the bits i'll take all the pics and right the guide out could be a sticky like cossie brake one
Oct 13, 2010 | 08:02 PM
Oct 13, 2010 | 08:06 PM
Oct 14, 2010 | 06:28 PM
wat size spacers do you need or is it just a simple bolt up job?
Oct 14, 2010 | 07:20 PM
u need 12mm spacers and longer bolts, then drill the hub carrier holes to m12 then bolt on
Oct 15, 2010 | 12:48 PM
glad to hear original servo is up to job but i've read the upgrade to a mk2 mondeo servo is very worthwhile, anyone tried it?
Oct 15, 2010 | 07:54 PM
ive seen it done on mk2 fiestas but not escorts
Oct 17, 2010 | 11:17 AM
12 spacers. Don't fancy that much tbh. No better ofset discs ?
Oct 17, 2010 | 10:56 PM
dont think so off the shelf can have bells and rotas made
lots of people do it you ever seen how things like aps/wilwoods mount lol
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
braided ,
brake ,
brakes ,
escort ,
lines ,
mk3 ,
mondeo ,
rs ,
spacers ,
st170 ,
turbo ,
upgrade
