help please rewiring fans
Hello,
I"m rewire my fans,Sapphire 4x4, but i have a dubble fan at the back of the radiator and one at the front for the airco.
can i put the + and the negative wire for the single fan for the airco olso on the new loom for the fans?? begause i did this and now when i put the ignition on the front fan is running, thats not right.
and were do i put on the little wire aux/sw
Hope you guy's can help??????
Thanks Bart,
Thanks Bart,
Keep the air con fan and the 2 main cooling fans seperately switched, do NOT join them.
With the fan rewire and it's new relay the wire that goes from the fan switch in the radiator is the one you want to hook into for a fan switch over ride, so assuming it is still switched positively from the original fan switch simply take a live to a over ride switch, then out the switch to the relay that the wire from the rad switch goes to.
30 is battery
85 is earth
86 is switch(fan switch in this case)(live)
87 is output
So hook into 86 to switch it manually from a over ride switch, remembering to switch off the over ride when you leave the car, or get a flat battery.
30 is battery
85 is earth
87 is output
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
