VW interior trim
Old Oct 10, 2010 | 05:37 PM
Default VW interior trim
Was cleaning a mates car today, with me lad, as it's going up for sale, a vw golf I couldn't believe the absolutely shocking shit plastic trim on the boot area running along the panel and the front panel below the scuttle panel area, I think I've seen thicker stronger crisps packets, trim was broken all over the place due to being seriously crap is this VW's legendary build quality at work, was a g reg btw, I was shocked tbh.
Mates just back from Iraq, and new born so strapped for time at the mo.
Old Oct 10, 2010 | 05:58 PM
155lee's Avatar
155lee
i found all mk2's are brittle inside.they have that black trim along the dash,thats usually missing,window winders break and they just seem a bit naff.not any worse than a s1 though.
Old Oct 10, 2010 | 07:24 PM
Really are s1 this bad ?, it's a 8v gti 1800, and frankly and seriously my gf's astra mk3 1400 automatic is faster, just.
Old Oct 10, 2010 | 07:28 PM
RichieST's Avatar
RichieST
I had a 10 plate VW Fox the other day as a courtesy car, the plastic round the ignition barrel was already scratched to buggery, the soft feel covering stuff on the inner door handle was peeling, ones of the bulbs behind the dash wasn't working, the coolant level was below minimum and the boot lid wouldn't shut unless you slammed it really, really, really fucking hard.
And this car had about 2500 miles on the clock!
Old Oct 10, 2010 | 08:01 PM
155lee's Avatar
155lee
what you usually find with s1's are the glovebox hinges are broken,the dash is cracked,the steering column cowling is broken,if the car is lowered the dash seems loose when going over bumps,the plastic things under the doorhandle break,the parcel shelf supports break.mk3 plastics seem to be made from different plastic to s2's.not every mk3 will be the same,but the used cars will show inside.most i have seen have had something broken inside.
Old Oct 10, 2010 | 08:33 PM
Rhys's Avatar
Rhys
I own a 2007 Golf GTI, and i dont rate the interior as that good tbh.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
