this manifold?
Looks to be made from argos, would work with the t70 shite ive been on about too
looks to have one of those t70 argos turbos fitted on the picture
for £500 inc the wastegate, mani and t70, i can make the screamer myself and 3" v band, seems quite cheap, not that it would last im sure!
http://cgi.ebay.co.uk/RS-COSWORTH-T4...item4153506cba
..... i just want a big turbo and external wg cheaply!
the likelyhood is this will crack as this part is put under alot of stress i.e heat ,weight of turbo,etc £500 will get you a fair way in your serch for a larger turbo
You can either buy or make up an external gate flange on the trouser section of the 2wd manifold. Big turbo, gt35 or whatever your preference. Dont see how there 'gay' mate? My advise would be- if its cheap and your in doubt- steer clear.
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
