torque setings for 6 nut an stud kit?
Old Oct 8, 2010 | 02:09 PM
turblower's Avatar
turblower
Default torque setings for 6 nut an stud kit?
as above could u please let me know the torque settings and also do i use the old 4 bolts or do i replace with new and also do the bolts have to be torqued down the same as the nut an studs?
much appriciated guys and soz if my gramour is a bit poo...
Old Oct 8, 2010 | 04:56 PM
turblower's Avatar
turblower
any1?
Old Oct 8, 2010 | 05:21 PM
ybturbo's Avatar
ybturbo
To be honest I don't know the torque settings for a stud -nut kit but for sure I wouldn't use old bolts as they stretch once torqued down.
Old Oct 9, 2010 | 04:12 PM
Toe Knee's Avatar
Toe Knee
If it's the same as a long stud kit there's always a debate as to what to use, I was advised used and went with that in the end because the they have been streched already they won't anymore and taking into account the arps arnt stretch bolts u want them to be the same!! Does it not say in the instructions?! Will dig out the settings I did my long studs too but not sure if arps are done the same or not!!
Old Oct 9, 2010 | 08:47 PM
Danny @ Enhanced Performance's Avatar
If its a proper stud and nut kit as i assume it is being the centre 6 then go 35lb 60lb then 90-95lb...
cheers danny
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
