MSD chip with ALS ?
Old Oct 8, 2010 | 08:29 AM
Heitmann's Avatar
Heitmann
Default MSD chip with ALS ?
Help needed please
have recently bought a new chip with ALS
I have now got round to to test it, and something seems a bit strange.
If I activate it via a switch, when the engine is cold, it will drop the rpm, and car becomes undrivable. Now I know that it is not supposed to pop and bang when cold, but seems wrong that it affects the way the car drives. I was of the impression that it just wouldn't activate if some of the ALS parameters wasn't met (like engine cold).
Have I misunderstood this - or installed it incorrectly?
When engine warm and if I rev it, it will pop a bit - but I will not test too much if something is wrong.
I have connected PIN 13 through an on/off switch to chassis earth.
And modified the ISCV - but no other modifications. (descriped as very mild ALS in the instructions)
any inputs highly appriciated
/Heitmann
Old Oct 8, 2010 | 08:50 AM
Karl 3dr's Avatar
Karl 3dr
When it's activated, it does affect the way the engine runs and how the car drives, the idle become very rough and the revs drop, also i found that the car wasnt nice to drive at low revs but thats not what it was designed for, it meant to be used when changing gear at high revs. It does sound strange that it works when the engine's cold though, best thing would be to contact msd i would say.
Old Oct 8, 2010 | 09:37 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Or get your money back and buy a proper als setup ???
Old Oct 8, 2010 | 09:57 AM
Heitmann's Avatar
Heitmann
Thanks for that explanation - I just also thought, like you, it shouldn't activate when cold.
Old Oct 8, 2010 | 10:04 AM
Why not just leave it switched OFF until the car is warmed up ?
Old Oct 8, 2010 | 11:26 AM
Karl 3dr's Avatar
Karl 3dr
That is one option I suppose lol although if its working when the engines
Cold then there's obviously a fault that needs rectifying?
Old Oct 8, 2010 | 11:31 AM
Heitmann's Avatar
Heitmann
oh but I do but you know the feeling if something is supposed to work in a certain way - it should. (my impression was that it shouldn't activate if engine was cold) - I might have misunderstood, which is why I ask if anyone have experience.
Old Oct 8, 2010 | 11:54 AM
JamesH's Avatar
JamesH
when you turn it on at idle the revs do drop, and the engine note changes. Never tried mine from cold. But it shouldn't activate at all when cold i thought?
have you tried phoning them?
Old Oct 8, 2010 | 12:06 PM
Karl 3dr's Avatar
Karl 3dr
No, it defo shouldn't work until the engine is up to a certain temp,
can't remember what it is now but Stu demonstrated it to me on mine when I picked my car up.
Old Oct 8, 2010 | 12:29 PM
Heitmann's Avatar
Heitmann
Thanks guys for the input
I would normally just call, but have got quite a lot of email support already from them on other stuff, so in respect would try to find answer here first
Old Oct 8, 2010 | 12:53 PM
martysmartie's Avatar
martysmartie
I am pretty sure you need to do a mod to the ISCV with ALS?
EDIT: Ignore that as I see you have done it.
Martin
Old Oct 8, 2010 | 01:14 PM
KSA-Cossie's Avatar
KSA-Cossie
70 degrees c iirc Karl.
Old Oct 8, 2010 | 02:24 PM
Karl 3dr's Avatar
Karl 3dr
Cheers Kev, my memory's shite, must be my age lol
Old Oct 8, 2010 | 03:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Know the feeling lol.
Old Oct 8, 2010 | 03:33 PM
Heitmann's Avatar
Heitmann
Thats closed loop - ALS is 50 degrees according to instructions
Old Oct 8, 2010 | 04:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Ah,i stand corrected m8. Have you called MSD to find out ?
Old Oct 8, 2010 | 06:12 PM
Heitmann's Avatar
Heitmann
surprised that I knew something...
Not called yet mate - will call them next week, when I have checked everything over again.
Old Oct 8, 2010 | 09:29 PM
KSA-Cossie's Avatar
KSA-Cossie
Cool m8.
Old Oct 9, 2010 | 09:40 AM
At least you have the bikini bandits in Denmark!!
Old Oct 9, 2010 | 08:21 PM
buttyrs's Avatar
buttyrs
what mods have you got to do to the iscv ?
Old Oct 9, 2010 | 08:43 PM
cozzy jeff's Avatar
cozzy jeff
Old Oct 11, 2010 | 06:00 PM
Heitmann's Avatar
Heitmann
sorry but got to disapoint you there - that was only a little gimmick, that ended too soon
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
