anyone into landrovers? discovery 1 Q?
hi, i have a discovery 1 that i use for off roading but ive developed a knock on the rear end, now id call the bar/ bush thats worn a V bar thats what we call them on trucks anyway. ive bein searching the net an i cannot find a replacment or a bush kit doin a search for "discovery 1 V bar" or "anti tramp bar" but ive had no look. now the bar is attached to the top of the rear diff housing & its sort of a ball joint/bush with 2 arms coming off it going to the chassis in the shape of a V hence the use of the term V bar.
can anyone tell me what landrover call these or were i can find a bar/bush kit.
cheers nic
cheers nic
cheers ill have a look for that, ive just been rakeing a rover website an came up that it may be called a fulcrum bracket aswell. were they get the names from i dont know lol
i cant rember what its called but ring john craddocks they will know number is 01543577207. there on the web to www.johncraddock.co.uk
nowt wrong with my disco mate
. befor i got it i was looking all over for a 110 because i used to have a 57plate when i was on the drilling rigs an new they were pretty much the best off road but cudnt find a cheap enough one so disco was 2nd choice but its spot on :P
friggin huge inside to, its like sitting in my shed
am just waitin to roll it then it will be roof off and make it into a pick up or flat back
Its called an A frame ball joint and here it is http://cgi.ebay.co.uk/Land-Rover-Dis...item3a4efdcfc1
Oh and there a bitch to get out and usualy need pressed or cut out.
cheers matem id call it a v or a frame but i couldnt find any, ive got a good press so ill manage
mates just picked is v8 defender up today should be pretty good fun too
