msd 380 converison advice please
Old Oct 7, 2010 | 04:47 PM
ginner's Avatar
ginner
Default msd 380 converison advice please
ill be picking my escos up in the next 2 weeks.and was goin to get the 380 conv ,just want 2 know wot have u had any probs with diffs and gearboxes,as 380 is over the supposed limit,didnt want to have to rebuild them after everytime it gets launched
Old Oct 7, 2010 | 05:03 PM
Altratz's Avatar
Altratz
you will be rebuilding your gearbox after every launch as you put it!!!!!
Old Oct 7, 2010 | 05:08 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Don't get the 380 conversion if you plan to give it a hard life with a load of standing start launches and don't want to be picking bits of transmission up, because it WILL break at some point. Alternatively, don't launch it all the time and it'll last far longer.
Cheers,
Grant
Old Oct 7, 2010 | 05:21 PM
cossie362's Avatar
cossie362
anyone have an idea on cost for this sort of conversion?
cheers
Old Oct 7, 2010 | 05:23 PM
WongRS's Avatar
WongRS
im running the 380 (albeit maybe slightly lower power as i have a .48) and have had no trouble at all, done about 15k with it at that power, done 30+ santa pod launches (anyone who's seen me launch will tell you, im not gentle) and it does get used, i dont abuse it but it does get driven properly.
3rd gear is the one to watch if its 4x4, dont build up the power from low rev's, my rule is dont boost 3rd gear unless its above 4k, seems to work for me.
Old Oct 7, 2010 | 05:26 PM
ginner's Avatar
ginner
Cheers,
Grant
i didnt mean that id be launching it everywhere .to be honest i will proberly never properly launch it anyway,wot i ment was have u guys bothered uprateing them to run that power
Old Oct 7, 2010 | 06:39 PM
Dave Hewy's Avatar
Dave Hewy
I did a 13.6 at pod with this conversion. If you launch it a lot your synchro rings wont last long, mine started crunching changing from 3rd down to 2nd but i didnt break any gears.
Price wise i was running stage 3 before and it cost me Ł1200 but i had the wasted spark done at the same time. I sold my old chip, greens, grp a coil and leads for Ł300 so it cost me Ł900.
Old Oct 7, 2010 | 06:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
380 wont brake iver it all depends if they can give any good low down torque thats what brakes your diff and gearbox!
Old Oct 7, 2010 | 06:49 PM
155lee's Avatar
155lee
whats needed for the 380 conversion?
im running a standard 4x4 cossie turbo on my 2wd saph,standard intercooler but it is stage 3 already with a turbosystems chip and 200 block'd 4x4 engine.ill prob need a t34 or similar and intercooler but what else is needed for the 380?
Old Oct 7, 2010 | 06:52 PM
ginner's Avatar
ginner
i take its a good package then
Old Oct 7, 2010 | 07:26 PM
THEDMAN's Avatar
THEDMAN
Does MSD's website not quote the 380 conversion at Ł750?
http://www.motorsport-developments.c..._packages.html
Old Oct 7, 2010 | 07:27 PM
WongRS's Avatar
WongRS
its awesome on the road, really drivable, but quick enough to see off most things you come across!
I really recommend it.
Old Oct 7, 2010 | 07:29 PM
saph4be's Avatar
saph4be
it's a excellent conversion and i never broke any transmission parts and use to launch it sometimes
Old Oct 7, 2010 | 07:32 PM
T34.48(or 55 63), injectors greys, blues, siemens, decent RS500 type intercooler, there's a genuine 3" RS500 behr one on the bay at the mo from a RS500, looks mint, obviously then chip to suit, or even better aftermarket management for future mods
Old Oct 7, 2010 | 07:35 PM
WongRS's Avatar
WongRS
and to add, just safety measures that are recommended, group a or similar H/G and a decent breather system, and if its a 4x4, then some new brakes! lol
Old Oct 7, 2010 | 07:42 PM
155lee's Avatar
155lee
reading about the closed loop,its 250 for the gubbins and 250 for the program to run it,or 500 for live mapping?what would be needed to get 400 bhp then?
Old Oct 7, 2010 | 07:44 PM
ginner's Avatar
ginner
it already has wrc h/g and big brakes so nearly there.oh will i need a cone filter or will a k&n panel be ok
Old Oct 7, 2010 | 07:45 PM
155lee's Avatar
155lee
its great that with such little outlay you have supercar power from an engine designed in the mid 80's.
my car has a fresh 4x4 engine in it but i think i would be better with the 2wd manifold as mine has the 4x4 1 and turbo,then i would need a different exhaust as i think the downpipe would be different.
ill have a look at the 1 on ebay,im waiting on ŁŁ coming in so im trying to stay off ebay the now!
Old Oct 7, 2010 | 07:53 PM
graham c's Avatar
graham c
mines running this set up but only 25 pounds of boost as i,ve not finished setting up and it gose like fook but my mk1 escort is lighter too
Old Oct 7, 2010 | 08:18 PM
saph4be's Avatar
saph4be
k and n panel will be fine you will also need a 3 bar map sensor stick with 4x4 exhaust manifold as i heard the 2wd one is a bit more laggy?
Old Oct 7, 2010 | 08:23 PM
ginner's Avatar
ginner
its a s/t escos thats been converted to big turbo 330 bhp so its has 3 bar map sensor but the exhaust housing on the turbo is a 48 where can i get a 63 from and how much
Old Oct 7, 2010 | 08:27 PM
graham c's Avatar
graham c
put a post up in here for a 63 housing
Old Oct 7, 2010 | 08:30 PM
ginner's Avatar
ginner
its done lol
Old Oct 7, 2010 | 08:33 PM
saph4be's Avatar
saph4be
just noticed you only in newark if ya need a hand gis a shout mate
Old Oct 7, 2010 | 08:38 PM
ginner's Avatar
ginner
I will mate and were not all pikeys b4 u say it lol.is ure saph white i was working in blidworth and seen 1 there a few times .im trying to sell my 4x4 saph if u know any1
Old Oct 7, 2010 | 08:42 PM
saph4be's Avatar
saph4be
mine was grey mate how much is yours pm me
Old Oct 7, 2010 | 08:47 PM
ginner's Avatar
ginner
pm'd mate
Old Oct 7, 2010 | 08:49 PM
James @ M Developments.'s Avatar
give me a call tomorrow mate and i will go through it with you
Old Oct 7, 2010 | 08:54 PM
ginner's Avatar
ginner
will do mate
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
