wanted big brakes for escort rs turbo mk4
Oct 6, 2010 | 04:17 PM
hi im looking for brake kit from 300mm to 330mm any make to fit a escort rs turbo mk4
Oct 6, 2010 | 04:50 PM
Oct 6, 2010 | 05:00 PM
reyland did mine mate 330 with 4pot ap's
Oct 6, 2010 | 06:14 PM
MK3 Mondy calipers and pads, 300mm Focus ST discs, 12mm spacer.... all from ebay for less than £100
Oct 6, 2010 | 07:02 PM
karlos is this alot better would you say over standard
Oct 6, 2010 | 07:10 PM
opening the door and sticking your feet on the floor is better then std
Oct 6, 2010 | 07:12 PM
how much did they cost? its just what im looking for
Oct 6, 2010 | 07:15 PM
Quote:
Originally Posted by
Mark RS
how much did they cost? just what im looking for
Oct 6, 2010 | 07:30 PM
most rst's don't need the door opening
Oct 6, 2010 | 07:34 PM
i know but wasnt sure of the condition of the op's car
mine was lucky to have the drivers seat still INSIDE the car
Oct 6, 2010 | 07:43 PM
bencossie
Yes Ben loads better!!
studabear
lmao!
Oct 6, 2010 | 09:24 PM
karlos mate, quick question if you don't mind but where does the spacer go on this? is it between the disc and hub? also does it matter what mk3 mondy callipers are used?
cheeRS
tom
Oct 6, 2010 | 09:31 PM
No mate, in between the hub and the caliper, the two bolts that hold caliper to hub get spaced out to bring the caliper out a bit and sit central on the disc.
Any MK3 Mondeo as far as I know.
Like this
http://cgi.ebay.co.uk/FORD-MONDEO-MK...item4aa5067d43
Oct 6, 2010 | 09:53 PM
ddfhill
think they were about £1500 cant remember as it was years ago
Oct 7, 2010 | 12:09 AM
karlos where did you get the spacer from and did you need longer bolts or the standard ones ok
Oct 7, 2010 | 02:43 AM
On this subject,what the biggest you can fit under standard dog leg rims?
Oct 7, 2010 | 05:23 AM
im sure its 285mm but dont quote me
Oct 7, 2010 | 06:28 AM
yeah i had 285 with cossie 4 pots behind my s1 wheel
Oct 7, 2010 | 06:59 AM
rsmark86
Ebay, and they came with longer bolts.
But I cant seem to find any on there right now
Oct 7, 2010 | 07:10 AM
studabear
lmao
Oct 7, 2010 | 11:18 AM
essexRSTSouthend
Dog leg rims are XR3i mate. Surely you dont have them on your S2?
Oct 7, 2010 | 02:01 PM
My mistake,the series 2 wheels
Oct 7, 2010 | 03:57 PM
gus what brackets and discs would i need to do this conersion as im looking at putting standard wheels back on for a bit .... will also run cossie rears with a bias valve
Oct 7, 2010 | 04:37 PM
i can never remember which way round it was
2wd discs 4x4 callipers
or theothe way round
will be covered in here somewhere
Oct 7, 2010 | 05:20 PM
I used 2wd disc's and calipers on my estate and they fit in my steelies
I did a small guide in the sticky at the top of the page when i fitted mine.
Oct 7, 2010 | 09:33 PM
Really.i just dont want to lose the original look.was going for willwood set but saw bad reviews on here about them leaking.so think set of cosworth ones will do the trick.
Oct 8, 2010 | 04:25 AM
what brackets were used to fit the 2wd calipers as dont they not bolt upto a rst hub like a 4x4 caliper does
Oct 8, 2010 | 04:13 PM
I didnt use any brackets i had a friend machine 4mm off the mounting face of the calipers to make them sit in the middle of the disc then drilled and tapped my hub to take the bigger bolts the cosworth uses
The holes on the caliper didnt quiet line up with the hub on mine so i opened the holes up by 1/2 a mm in the caliper to give abit of clearance and they bolted straight on.
Mark.
Oct 8, 2010 | 04:53 PM
Oct 9, 2010 | 07:55 PM
Karlos G
sweet im doin this what mondey calipers? any
Oct 10, 2010 | 01:14 PM
marky_g
All mk3 mondeo calipers are same
Oct 10, 2010 | 05:24 PM
marky_g
tasos77
Yup
Oct 10, 2010 | 07:19 PM
Oct 10, 2010 | 11:01 PM
marky_g
sweet!!!!!
and easy.....
Blown Hell
Aug 5, 2015 07:22 AM
adriansaleem
Aug 3, 2015 11:21 AM
adriansaleem
Aug 1, 2015 09:28 PM
Old ford
Jul 31, 2015 06:50 AM
big ,
brake ,
brakes ,
cross ,
discs ,
drilled ,
escort ,
fit ,
ford ,
mk4 ,
passionford ,
rs ,
technical ,
turbo ,
upgrade
