FRST Fuel Pressure Regulator
Old Oct 5, 2010 | 11:09 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Default FRST Fuel Pressure Regulator
Hi all,
Can these be bought direct from Ford still or are they now a pattern part item and if so where can they be bought from.
Does anyone have the part code ref etc.
Thanks
Barney
Old Oct 5, 2010 | 11:11 AM
chaffe's Avatar
chaffe
Turbocharging Technician
same as an xr2i or xr3i efi one mate if that helps
Old Oct 7, 2010 | 12:02 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Thanks..
Does anyone know any where these can be purchased on line...
Old Oct 7, 2010 | 12:08 PM
Danster76's Avatar
Danster76
When I bought one this time last year, Fords were wanting 250 ish I got one from a motor factors for about 50 and it was the webber one ford supply anyway
Old Oct 7, 2010 | 01:48 PM
chaffe's Avatar
chaffe
you could always get an fse adjustable one, be sure to set the pressure correctly with a gauge first though.
Old Oct 7, 2010 | 04:04 PM
rsmark86's Avatar
rsmark86
what can a standard one flow to as i still need to uprate mine ..... will it need replacing to run 280bhp
Old Oct 8, 2010 | 09:22 PM
gup's Avatar
gup
i wa told not to run the 2i one as they dont fuel under boost
better of trying to get a proper turbo one or cozie one fella
Old Oct 9, 2010 | 08:41 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
FRST and XR2i are the same reg's Gup.
Both of them have a vacum feed and will increase fuel pressure when needed.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Dubs44
Sep 19, 2015 06:31 AM
