standard mk3 escort i want
Old Oct 1, 2010 | 10:56 AM
shaneb677's Avatar
shaneb677
Default standard mk3 escort i want
i want to take out the old 1600injection cvh and if poss replace with something that will give me that little extra power needed but the most easiest way to do it im not to clever at mechanics but willing to learn so if any one has any tips or advice that would be great i dont want a turbo just something simple cheers guys
Old Oct 1, 2010 | 11:25 AM
shaneb677's Avatar
shaneb677
been told an xe engine will go straight in to my escort mk3 is that not a vauxhall engine?
if so how can it?
Old Oct 1, 2010 | 12:08 PM
dingla rs's Avatar
dingla rs
2ltr outa mondeo not sure what box you need ,look it the build treat forum pal probly a rst box
Old Oct 1, 2010 | 12:12 PM
Mr.T's Avatar
Mr.T
and 1.8 escort oilpan,waterpump etc.
Old Oct 2, 2010 | 12:27 PM
shaneb677's Avatar
shaneb677
not much help
Old Oct 2, 2010 | 12:39 PM
Mr.T's Avatar
Mr.T
There is no really easy way. You will need the complete engine incl loom etc.
Old Oct 2, 2010 | 12:45 PM
performace_ford's Avatar
performace_ford
Nae Bither!
I put a 1.8 zetec later silver top in my escort this is the easiest route to go you dont have to change the sump, pick up, and water pump also dont need to change the flywheel either. You even use the cvh engine mount, the best gear box to go for would be the s1 turbo box again bolt straight up. You need to use the zetec loom, i used one from a fiesta si. With the proper tools and parts this can be done over a weekend.
Old Oct 2, 2010 | 12:50 PM
Patto's Avatar
Patto
im going to be doing this to a mk4 soon, the engine stuff aint a problem but the wiring in of the loom is what im not sure of, do you have a diagram of chopping in the zetec loom??
Old Oct 2, 2010 | 02:07 PM
Mr.T's Avatar
Mr.T
If you go 1.8 escort Zetec you don't have to change yes. But for the 2.0 mondie setup you have to change things
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
