Turbo Carbs?
Old Oct 1, 2010 | 06:15 AM
rich201283's Avatar
rich201283
Default Turbo Carbs?
How well would a would the turbo carbs below work on a 2.0 zetec?
Renault 5 turbo carb
Montego turbo carb
I am already useing megajolt so mapping is not a problem, I was goig to use a t25 turbo.
Has anyone done this before with either carbs.
Old Oct 1, 2010 | 06:28 AM
chaffe's Avatar
chaffe
Turbocharging Technician
i wouldnt bother mate, upgrade to full MS and efi the zetec, also a t25 will be a little on the small size if you wish to rev the zetec past 5k, for both montego and ren set ups you will still need a high pressure efi pump and fuel lines, and fuel pressure regulator, so you be as well running a full efi setup, much more tunability. You got bike carbs the now like?
Old Oct 1, 2010 | 07:30 AM
rich201283's Avatar
rich201283
hi
Yea im running zx9r carbs with megajolt, was just thinking about keeping the costs down. If i went efi i need a efi manifold and megasquirt which adds up to quite a bit of money.
I cant use the standard manifold due to the restriction in heigh due to it bee a kit car
Old Oct 1, 2010 | 07:43 AM
chaffe's Avatar
chaffe
Use the bike carbs and turbo it then mate, rising rate fpr, and make sure all the breathers on the carbs see boost
Old Oct 1, 2010 | 06:16 PM
If you use the carb as suck through then a huge amount more carbs to choose from, and suck through has some good advantages.
Old Oct 1, 2010 | 06:25 PM
chaffe's Avatar
chaffe
he has four carbs though so thats not pos mate, you can modify them for a blow through set up though
Old Oct 1, 2010 | 07:47 PM
Shings's Avatar
Shings
Speak to NMS ( Norris Motorsport ) Karl did a project for a mate of his
Webber 45's and a T3 - was fucking imense.
Old Oct 1, 2010 | 07:48 PM
Shings's Avatar
Shings
Ps the noise - its awesome
Old Oct 1, 2010 | 08:32 PM
Just ditch the shitty bike carbs and fit a REECE FISH with a nice turbo.
Old Oct 2, 2010 | 10:27 AM
chaffe's Avatar
chaffe
whats that then tabetha? sounds abit fishy lol. Is it a turbo specific carburetor? what sort of costs are they? if its too dear then i would be going efi route
Old Oct 2, 2010 | 03:20 PM
Reece Fish is a oddball carb with simply three allen keys that are turned to adjust the fuelling to suit the engine used, never seen one myself but were supposedly awsome bits of kit.
Old Oct 4, 2010 | 05:33 AM
chaffe's Avatar
chaffe
like an old Sufolk punch lawnmower carb, i had one on a motorbike once, when i was 15. Was good fun, you could adjust the mixture and generally tune it. Saves a lot of money on jets and time taking carbs appart!
Old Oct 4, 2010 | 08:37 AM
Jasesapphy's Avatar
Jasesapphy
Dont use the Montego carbs, we had those on our maestro and we could never get the fueling perfect across the range, hence we are on injection
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
