transit connect problems ***with pics***
Old Sep 29, 2010 | 07:01 PM
marky_g's Avatar
marky_g
Fleet Manager
Default transit connect problems ***with pics***
just been given a transit connect thats had its engine replaced was a mechanical failure bottom end so i assume juved replace only the engine not the wiring but apparently it wont start the fuse box is hanging out and its not totaly back together
anyone got any ideas or tips or things that should be done when changing the engine?
Old Sep 29, 2010 | 07:05 PM
Icurus's Avatar
Icurus
Petrol or diesel?
Old Sep 29, 2010 | 07:07 PM
Check the wire from the battery to the starter. There is a shit connection in the wire that breaks. Its a live wire by the way. They break on the royal mail vans all the time. Just cut the connector out and rejoin the wire.
Old Sep 29, 2010 | 07:08 PM
Karl 3dr's Avatar
Karl 3dr
If its just a straight engine change then you dont have to do anything, i.e programming wise, just swap the engine and away you go.
I presume it cranks?
Does the pats light flash really fast when its cranking?
Old Sep 29, 2010 | 07:13 PM
marky_g's Avatar
marky_g
Fleet Manager
thats what i thought it would be straight forward unfortunaly i cant ask the place that did the swap as there no longer in business, i dont no anything just yet as i have not seen the van since the swap but ive been told the fuse box it out half the dash is out and parts are in the back!!!
i'll be gettin in saturday afternoon and putting it back together, just wondering what problems they might have had to make them need to strip the fusebox and look at wiring
its a swb low roof L200
Old Sep 29, 2010 | 07:22 PM
Icurus's Avatar
Icurus
Again, petrol or diesel?
First port of call would be to get it all back together electrically
Karl 3dr's Avatar
Karl 3dr
Not really sure tbh, like i say, it should just be a straightforward engine swap, i think i'd be tempted to put it all back as it should be and work from there,
Cheers, Karl
Old Sep 29, 2010 | 08:05 PM
marky_g's Avatar
marky_g
Fleet Manager
diesel mate lol i;ll start my building it back up
Old Sep 29, 2010 | 08:14 PM
dojj's Avatar
dojj
Resident Wrestling Legend
maybe they chaned the ecu and it needs a key to go with it?
Old Sep 29, 2010 | 08:42 PM
marky_g's Avatar
marky_g
Fleet Manager
its possible but why would the do that is it possible to get a key coded to that ecu if its been changed?
Old Sep 29, 2010 | 09:20 PM
Icurus's Avatar
Icurus
The diesel pumps need to be coded to the ignition/ecu, so if they did not use the old pump then that might be a problem?
Old Sep 29, 2010 | 09:42 PM
Karl 3dr's Avatar
Karl 3dr
Old Sep 29, 2010 | 09:50 PM
Karl 3dr's Avatar
Karl 3dr
Connect pumps don't need to be coded, the pats is in the instrument cluster iirc, yes you can code your existing keys to a different ecu, don't know why they would have changed it though, unless they changed the wiring loom/ecu at the same time as the engine?
Old Sep 30, 2010 | 06:20 PM
Icurus's Avatar
Icurus
According to TIS;
5. Configure the fuel injection pump to the powertrain control module (PCM). For additional information, refer to WDS.
6. Using the special tool, prime the fuel injection pump until clean fuel is seen entering the vacuum pump reservoir.
Old Sep 30, 2010 | 08:06 PM
dojj's Avatar
dojj
the fusebox is behind the glovebox right?
Old Sep 30, 2010 | 09:17 PM
marky_g's Avatar
marky_g
Fleet Manager
like i say i havent seen the van since its had work done im goin to look at it saturday maybe do some work while im over there then get it trailered back to my place to get it all sorted
but the fuel pump things the kind info i needed as id never even think of that lol
Old Sep 30, 2010 | 09:34 PM
Icurus's Avatar
Icurus
There are 2 fuseboxes Dojj, and one of them is indeed behind the glove box, the other is near the battery
Old Oct 1, 2010 | 12:48 PM
dojj's Avatar
dojj
So which one have thy pulled out then? If it's in theengine bay you can say it's for space reasons, but under the dash? WTF they playing at.
Old Oct 1, 2010 | 12:57 PM
kent discos's Avatar
kent discos
Transit Connect Owner
connects have problems like this, another one is the crank sensor which is hidden at the bottom and at the back of the engine, apparently if this isn't plugged in or is faulty, then the connect engine won't turn over.
true aswell:
1) Cable between battery, alternator and starter are prone to wear and tear and will break, resulting in a non starter/battery light coming on and off on dash.
2)afaik the diesel pump does need coding to the ecu for it to work properly
3)also afaik the pumps are self priming? - depends on the year?
4)2 fuseboxes - one under bonnet by battery for all externals and relays, one fusebox inside which does all the little fuses, lights, radio, etc. (the usual stuff)
is it the TDCi engine or TDDi and what size engine is it? 75, 90 or 110?
Old Oct 2, 2010 | 06:16 PM
marky_g's Avatar
marky_g
Fleet Manager
right some pictures of the monstrosity of wiring!
i have the ecu but dunno what else im missing cant believe some of the bodges there what were these fuckers [playing at
Old Oct 2, 2010 | 06:31 PM
dojj's Avatar
dojj
was about to say "it won't start if it ain't got an ecu"
why are they running cables from the relays?
Old Oct 2, 2010 | 06:40 PM
kent discos
this is the same post as on the ford transit forum, yes?
Old Oct 2, 2010 | 06:46 PM
gup's Avatar
gup
to me that looks like they have tried to by pass the the pats system
i think it stops you cranking the engine
Old Oct 2, 2010 | 10:24 PM
marky_g's Avatar
marky_g
Fleet Manager
yer mate joined a while ago, thought id get more help there
fuck knows what they've done the IC is off aswell for some reason im gonna take all the wires off that they have put in refit the ECU and get it on diag machine or to a proper firm im sure they'd have just changed the engine turbo and inlet but cant be sure
Old Oct 3, 2010 | 12:28 AM
kent discos
you sure its not nicked?
Old Oct 3, 2010 | 12:59 AM
marky_g's Avatar
marky_g
Fleet Manager
no mate its had a engine replace and by the looks of it the couldn't get it to run, not nicked been i own it lol no record of it being stolen
Old Oct 3, 2010 | 07:17 AM
kent discos
just checking
what engine did they replace it with?
Old Oct 3, 2010 | 07:50 AM
Icurus's Avatar
Icurus
It does sound as if they did not get the required parts coded to the van's ecu?
Does it crank over?
As you say, best to put it all back together and go from there
Old Oct 3, 2010 | 07:52 AM
marky_g's Avatar
marky_g
Fleet Manager
not sure id think what ever came out all i no its 1800 im sure it was tdci
Old Oct 3, 2010 | 08:18 AM
Icurus's Avatar
Icurus
From the very few TDCi's that I have seen, the injectors are all connected to a common distribution object, which then connects to the pump.
The Tddi's, which I have, the injectors all run back to the pump.
Old Oct 3, 2010 | 04:32 PM
kent discos
yeah, could be the 75, 90 or 110
only reason i ask is that on the 110 the turbo wastegate is electronically controlled, the common rail is like a big spider in front of the engine rocker that goes off to each injector and other end to the fuel pump.
do you just want to keep it a standard van, because you could turn it into an RS connect
Old Oct 3, 2010 | 06:47 PM
marky_g's Avatar
marky_g
Fleet Manager
right its a 75 tdi so not tdci
ha ha no mate i want it to be a diesel id love to di it but thats be a S2 RST, xr3i turbo, xr2 turbo and a connect with frs lol sod that
marky_g's Avatar
marky_g
Fleet Manager
thats exactly what i was thinking
Old Oct 4, 2010 | 04:35 PM
kent discos
ahh thought was there anyway....
i have the 75 Tddi to, so if you need any pics of anything or anytime let me know.
Old Oct 4, 2010 | 08:51 PM
marky_g's Avatar
marky_g
Fleet Manager
defo mate i'll be in touch through transit site nice one
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
biggiejody
Sep 19, 2015 10:25 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
