4x4 Cossie Gearbox rebuild??
right, i have got the box out of the cossie and i have been told that it needs 2nd and 3rd gears, synchros and the couplings fucked, says its going to be 350 to fix it.
My question is, would it be worth my time to get a decent set of internals put in, the cars running 383bhp just now but moneys getting a bit tight, in fact its getting really tight! Building cars aint cheap! Can anyone recomend decent internals, rough costs and what is included, i dont know what i am looking for......i take it he means the centre diff is the coupling, i know the diffs knackered after seeing it on the rollers
unforunately there are no 'cheap' gearsets available, might be worth rebuilding it to original spec, or just finding a replacement if money is tight? at that power though, its like a time bomb. have you ever considered going 2wd? saves some of the 'if i put my foot down, i may hear a loud grinding noise' worry!
the diff in the box isn't a "diff", it's a viscous coupling that fails when it gets too hot so you can either get a new one or pump the old one up, apparently cts do them in various forms at varios locked levels but it'll cost half your rebuild costs
don't push it hard until you can either drop the power to more usable levels or can save some pennies
or get a 2wd box
or get a 2wd box
or get a 2wd box
or get a 2wd box
DixieTheKid
Jul 23, 2023 10:16 AM
cossiedean84
37
Sep 2, 2015 10:19 PM
