Bosch 044
hi mates
been thinking about changing the standard fuel pump ( 20 years old now
) on my stage 1/ MSD EPROM 4x4 sapphy: is it wise / ok to go for the 044 upgrade ? or are there drawbacks ?
looking forward to your views on this matter
many thanks
many thanks
Is it really that noisy !!!!!!!!!!!!!!?
2 more questions: what should be the value of the fuel pressure at idling ?
is there a test i could perform to know to condition of the standard fuel pump?
thanks
thanks
There is no need unless you suspect something is wrong? So long as the fuel filter is good.
MOST importantly is the fuel pump wiring, the standard wiring degrades due to the age and so the pump doesn't get the power needed you want to see alternator voltage when the pump is UNDER load, this needs to be right whatever pump you have.
As said it depends on what valve the author of the chip has written for. Standard pressure is 3.5 BAR, I am pretty sure MSD write for standard fuel pressure on most chips?
Martin
Martin
im not sure if he does or not, but its that sort of use that could have a higher pressure, some small turbo esc cos packages do for sure as people cant map them lol and im constantly removing uprated regs from them
Ok guys let me rephrase the question
: With new fuel pump rubber mountings will the 044 be noisy? the old 941 i have on the sapphy on fresh rubbers there's absolutely no noise at all but there was quite some buzzing noise prior to replacing the deteriorated rubbers.
thanks to all for your informative opinions.
James, isint the extra capacity for future upgrades reasoning as james kiely puts it good enough to go for the 044?
if u think u will ever up the power then why waste your money on a standard one? get an 044 then u no its far better than needed anyway and will be good right up to 500bhp if u get bored and tune it more
Would the standard fuel pipes : feed + return be able to handle the extra flow of the 044 without undue increase in back pressure on the pump and hence current demand. BTW i have rewired pump using 2 x 2.5mm2 copper cable runs as +ve and a good nearby earthing -ve point.
if you only plan on running stage 1-3 then an 044 will give you no benefit at all.
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
