EGT sensor location
Old Sep 28, 2010 | 06:12 PM
sir nose's Avatar
sir nose
Default EGT sensor location
can i fit an EGT sensor here with the correct adaptor?
i worry some moving parts inside the turbo may foul the sensor.
Old Sep 29, 2010 | 07:52 PM
dakunia's Avatar
dakunia
I think some small parts from sensor (if poor quality or if it be defective) can destroy turbo shaft blades.
I heard better position is after turbo, on down pipr, around 2 inches after turbo flange. Saw on pics lot solutions this way, but maybe any expert can confirm it?
Exhaust gases are colder alongside with distance from engine.
regards
maciek
Old Sep 30, 2010 | 07:12 PM
Just have a look see what is in the hole, and how long the sensor probe is.
I can always make another fitting on the lathe that is longer so doesn't protrude into the hole so much if you want.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
AJC
Oct 1, 2015 06:47 PM
Steve Escos
Oct 1, 2015 06:57 AM
