Anyone know the 2wd power steering capacity
As title I need to add some stop leak as a temporary measure as the MOT is coming up it says 5% by volume, it does not say in the workshop manuals.
Cheers tabetha, as you can see from the other thread in tech Q&A that you replied to I think that I probably have to take it off and get it checked over, because if the rack support bush is coming loose I think I would need more than some stop leak treatment to cure it, and would probably need a Ambulance if I use it.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
