how does a engine stand work?
Old Sep 27, 2010 | 07:52 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default how does a engine stand work?
as above, i wanna get a engine stand but how they bolt onto the engine etc?
Ebonycossie4x4's Avatar
Ebonycossie4x4
Erm you bolt your engine to it.
How else can it work, its an engine stand!
Old Sep 27, 2010 | 07:53 PM
Ebonycossie4x4
a lot of people use studding with nuts on the ends.
Old Sep 27, 2010 | 07:54 PM
paul16v's Avatar
paul16v
Monte 087
You bolt the engine to the stand through the bellhousing bolt holes, the arms on the stand are adjustable to suite different engines.
mrjenrst's Avatar
mrjenrst
Can you not get the one's that make the big old heavy engine float in mid-air? Lol
Old Sep 27, 2010 | 07:57 PM
Ebonycossie4x4
I hear david blaine has one yes.
Old Sep 27, 2010 | 07:59 PM
mrjenrst's Avatar
mrjenrst
Wonder if he fancy's selling to the op?
Old Sep 29, 2010 | 05:43 PM
www.machinemart.co.uk
do a few versions, I have the T version with a single long leg and short t part, gives more room for your feet than the ones with parallel legs, had loads more weight on mine than rated was no problem, easy take a cossie with all ancillaries etc.
Old Sep 29, 2010 | 05:49 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Same as Tabetha, some go for the parallel legs as when trying to bolts heads on etc they're more balanced but tbh I think you'd have to be a compete dick to topple one over.
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
slammedorion
21
Aug 6, 2015 11:38 AM
