Body shell
Old Sep 27, 2010 | 07:24 PM
mk2-galicia's Avatar
mk2-galicia
Exclamation Body shell
HELLO I WANTED TO KNOW IF SOMEONE GIVE ME AN EXPLANATION OF 4 MOUNT LINK AND REAR turrets WATTS MARKS WITH MOUNTING OR ACTION WHAT YOU CAN
Old Sep 28, 2010 | 06:45 PM
HI,
A 4 mount link usually refers to a live axle, where it has a upper and lower link going between the axle casing and the body of the car, the reference to "watts" I assume is a WATTS LINKAGE ?, this is rod arrangement that has a "S" shaped bit in the centre of it, stretching across the rear of the axles diff, it has a bolt in the centre around which the S"S shape bit can pivot, the top and bottom of the "S" have a bar/rod attached one going to each side of the car and attached to the body, this serves to hold the axle centred when forces try to move it sideways, the axle is free to move up and down, as the "S" shape bit revolves around it's centre but as it is bolted to the axle centre stops any sideways movement of the axle in relation to the car body.
Rear turrets are the same as a lot of cars have on the front a McPherson strut type suspension leg held at the top and sitting inside a "turret"(tube effectively) made into the body of the car above each rear wheel for independent suspension.
Old Sep 28, 2010 | 07:51 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Pop on to www.oldskoolford.co.uk and have a look in there, I think its in the restoration section under Retro Motorsport, he has a lot of info how to fit etc.
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fil
Sep 30, 2015 12:08 PM
