Zetec Blacktop waterpump question?
Old Sep 27, 2010 | 02:20 PM
AustenW's Avatar
AustenW
Default Zetec Blacktop waterpump question?
I want to remove the power steering system but drive the pump the right way
Any solutions?
Old Sep 27, 2010 | 03:06 PM
dug112y's Avatar
dug112y
passionford pro
can you not drive it off a step off toothed wheel on the timing belt idler...similar to a dry sump set up ??
Old Sep 27, 2010 | 03:09 PM
AustenW's Avatar
AustenW
engine mount in the way
Old Sep 27, 2010 | 03:14 PM
dug112y's Avatar
dug112y
passionford pro
try these
http://www.dunnellengines.com/zetec_...partno=RMP1432
http://www.dunnellengines.com/zetec_...partno=RMP1480
Old Sep 27, 2010 | 03:16 PM
massivewangers's Avatar
massivewangers
Track Designs do a fitting kit to slot the black top into a Ka etc. That comes with a little conversion kit if you want to run without PAS. Basically has an idler pulley that replaces with PAS pump, might be of use?
Here it is: http://www.trackdesigns.co.uk/zetec-alt.htm
Obviously comes with all the alternator bits, but they might be able to help out.
Old Sep 27, 2010 | 03:21 PM
AustenW's Avatar
AustenW
Looks interesting
I hope that idler pully fits the focus RS waterpump
Old Sep 27, 2010 | 03:47 PM
dug112y's Avatar
dug112y
passionford pro
austen, do you have a spare st170 water pump housing kicking around?
i have a 107 mile st170 engine thats going in an autograsser and the pipe outlet on the housing is broke.
Old Sep 27, 2010 | 05:20 PM
AustenW's Avatar
AustenW
no i dont but the st170 is a regular blacktop pump
Old Sep 27, 2010 | 05:27 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I've probably got one kicking around - let me know if you're still after one.
Old Sep 27, 2010 | 05:30 PM
dug112y's Avatar
dug112y
passionford pro
i will do will. i need to be getting one of them breathers too mate.
Old Sep 27, 2010 | 05:36 PM
AustenW's Avatar
AustenW
I called dunnell up about their pully system and told the guy it was for a Focus RS water pump, he then started to argue with me that they were the same until I pointed out the differences, they guy got well shirty, I've spoken with him before and he thinks he knows it all lol
Anyway I'm going to make something up myself that is similar to their setup but better
Old Sep 27, 2010 | 06:50 PM
Rick's Avatar
Rick
idler pulley on mine.
Old Sep 27, 2010 | 09:31 PM
AustenW's Avatar
AustenW
problem solved, made this up tonight, will powder coat it satin black tomorrow
Old Sep 27, 2010 | 11:01 PM
JPA's Avatar
JPA
that looks tidy , where did you get the engine mount if you dont mind me asking ?
john
Old Sep 27, 2010 | 11:07 PM
dug112y's Avatar
dug112y
passionford pro
nice job austen ...all in a days work eh. am down lincoln way tomorrow to pick up an engine
Old Sep 28, 2010 | 08:11 AM
AustenW's Avatar
AustenW
john
Central Florida Motorsport in the USA
Old Aug 11, 2011 | 08:37 PM
DPUD's Avatar
DPUD
first thats a gorgeous engine dude.
next need to know a price if you fancy mocking me up a pully bracket?
Old Aug 12, 2011 | 08:32 AM
AustenW's Avatar
AustenW
Its alot of hastle to do one
It took me the best part of a day to make mine from scratch TBH and I valve my spare time to much to make stuff for others at the moment
What waterpump are you running?
Old Aug 12, 2011 | 08:55 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
An alternative is keep the power steering bracket and use a mazda pulley(part number somewhere) and an 1134 6pk belt.
All bolts straight up.
Fiddy
21
Sep 29, 2015 06:10 PM
dombanks
Sep 21, 2015 08:38 PM
focuspower
Sep 20, 2015 03:51 AM
Chopshop85
Sep 12, 2015 06:42 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
