1999 W reg Focus - slipping clutch ?
Old Sep 26, 2010 | 02:06 PM
NomadPaul's Avatar
NomadPaul
Default 1999 W reg Focus - slipping clutch ?
I was hoping for a bit of advice concerning my focus .
Its a 1.8 zetec model , w reg ( 1999 ) and i think the clutch is slipping. When i accelerate it races at lowish revs, seemingly with no power , but will then pick up albeit slowly. Does this sound like a slipping clutch ?
If it is slipping , is it terminal for the clutch or is there any adjustments that can be made ?
If it needs replacing , what costs , parts and labour , would i roughly be looking at ?
Its just what i don't need now so any advice will be gratefully recieved .
Paul
Old Sep 26, 2010 | 02:17 PM
phil_focus's Avatar
phil_focus
if say your doing 50mph in 5th, put you foot down and the car doesnt accelerate but the engine revs increase then your clutch is worn out and needs replacing. prob about £350 ish at a garage.
Old Sep 26, 2010 | 06:49 PM
Sounds like a slipping clutch, but shop around a lot as prices vary hugely.
Old Sep 26, 2010 | 06:52 PM
NomadPaul's Avatar
NomadPaul
Cheers . that does happen although it seems to occur mainly just after i've changed gear but still when i'm accelerating rather than constant speeds.
Oh well , better start checking out local prices.
Again , thanks for your thoughts
Paul
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
