removing window tints
Old Sep 26, 2010 | 10:41 AM
MannheimAlex's Avatar
MannheimAlex
Default removing window tints
It seems they where fitted by a pro, so I am afraid it is a bit of a pain in the *** to remove them...
Is there a special way to get rid of them?
Old Sep 26, 2010 | 10:43 AM
left hooker's Avatar
left hooker
the stanley one 2nd one down
http://shop.ebay.co.uk/?_from=R40&_t...ll-Categories#
Old Sep 26, 2010 | 10:46 AM
STeve's Avatar
Super Moderator
rear window is biggest problem if you scrape it you likely to break all the elements.sometimes you can heat them up and apply soapy liquid and peel them off,as for all side windows I would simply scrape with single edged blade with care again using soapy water
Old Sep 26, 2010 | 11:26 AM
MannheimAlex
Thanks,
will give it a try with the soapy water and a head gun.
Maybe the tar remover I used the other day to remove some stickers will also work?!?
Old Sep 26, 2010 | 08:07 PM
If it's decent film you can just get a edge with a corner of a stanley blade or similar and peel off, rear window as said will be dodgy to do, most likely will need renewing due to broken wires.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
