Torque settings plz !!!!
What engine, there are loads if a 1400/1600 SOHC then 25Nm then 60 degrees 3 times, each set in order ie 25Nm then 60 degrees on all, then another 60 on all then another 60.
if 1800/2000 25Nm then 90 3 times, then 60Nm.
If DOHC 1400/1600 25NM then 90 degrees 3 times then 45 degrees, then 60Nm, for 1800/2000(dohc) 25Nm then 90 degrees 3 times, then 60Nm.
The sets must be done in sequence, all in haynes manual 1832.
