zetec lump
Old Sep 25, 2010 | 06:11 PM
si20vturbo's Avatar
si20vturbo
Default zetec lump
hi just wondering if anyone knows what box will fit on the mondeo zetec lump to make it rwd as its going in my kit car? cheers
Old Sep 25, 2010 | 07:02 PM
Dlatch!'s Avatar
Dlatch!
type9 sierra/cortina/escort fits straight on
ps www.locostbuilders.co.uk
Old Sep 25, 2010 | 07:04 PM
Just make sure the type 9 is not a V6 type 9, as these have a different input shaft(longer).
Old Sep 25, 2010 | 07:09 PM
Garage19's Avatar
Garage19
Type 9, MT75 or T5.
I've fitted the later two. MT75 needs a modified release bearing. T5 needs a new flywheel.
Old Sep 25, 2010 | 08:18 PM
si20vturbo's Avatar
si20vturbo
iv got the type 9 box and the starter is in the wrong place
Old Sep 25, 2010 | 11:16 PM
Dlatch!'s Avatar
Dlatch!
which side is it mounting on ? (when looking at front of engine) should be on the right handside
not sure on the difference in bell housings but any from a pinto powered ford will do the job
what kitcar is it going into btw?
Old Sep 26, 2010 | 03:52 PM
si20vturbo's Avatar
si20vturbo
when looking at the front of the engine it is on the top left and on the box it is on the bottom right and it is going in a robin hood kit car
Old Sep 26, 2010 | 04:35 PM
mark_24v_wiring's Avatar
mark_24v_wiring
When fitting a type 9 to the back of a zetec the starter location changes from std zetec position to the pinto position you will then find that 1 bolt hole from the type 9 wont do up as there is nothing there to bolt it to.
2 things you need to make life easy is the 1.8 escort flywheel that is listed on retro ford
http://retroford.co.uk/retro-shop/pr...products_id=93
Its been re-drilled to accept a pinto clutch or you could re-drill your own 1.8 escort flywheel if you have one.
and the spigot bearing
http://retroford.co.uk/retro-shop/pr...roducts_id=209
Did all this to a mk1 escort over the last month so i know it all works as it should do
Old Sep 26, 2010 | 04:59 PM
si20vturbo's Avatar
si20vturbo
is there 2 types of zetec lumps then because there is no way to move starter on this lump that i have the only thing i think i can do is find some one that modifies the bell housing for the type 9 box?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
