Cosworth bits to clear
I will add more as they come up,pm if you want pics.
Virgin Cosworth 4x4 crank. May need first grind or polish In good order
£200 plus postage
Full set of 4, C.P pocketed 7.2:1 Forged pistons, covered 500 miles! In +0.75 size. Totally mint with rings and pins. Cost near £700!
£325.00 plus postage
Set of 4 Cosworth 4x4 con rods, mint cond, with ARP bolts,
£60.00 plus postage.
L8 T34.48,std cams, 55lb siemens, Closed loop, Low comp, ported head CHIP for std ford board,
£150.00 plus postage. (Retail £350.00)
L8, T4, 83lb, closed loop, low comp 7.2:1, ported head, Air injectors, BD14ex BD16 in cam, CHIP for std ford board will do 500bhp!
£200.00 plus postage. (Retail £400.00)
£200 plus postage
200 Motorsport block, on .75 bore, needs a liner fitted as there is too much piston-bore clearance on one pot, simple fix...
Has 6 New type long studs fitted, had deck skim 500miles ago.
Hi has this got the filled in filter housing and rear oil intake/return?
cheers
cheers
someone gave me a deposit nearly a year ago, and has given numerous exuses as to why the other 1k hasnt been paid, im not a storage department
would you sell that hose off the bottom of the water pump and if fezzajsy doesn't want the alternator that aswell?
cheers
steve
cheers
steve
Updated with remaining parts!
£200 plus postage
Full set of 4, C.P pocketed 7.2:1 Forged pistons, covered 500 miles! In +0.75 size. mint with rings and pins. Cost near £700!
£200 plus postage
TrevCos
Aug 22, 2015 06:05 PM
borboyous
Aug 22, 2015 11:17 AM
Aug 14, 2015 07:29 AM
