Oven not working
1st choice element gone.
2nd wire burnt off end of element or thermostat
3rd Thermostat gone
Take the front cover off the element and you may see a lump blown out of the side of it.
If so it's gone
3rd Thermostat gone
If so it's gone
Could be an electronic problem.my smeg did it/does it.try switching t'oven on without the fan and see if it heats up,mine does,and then the fan kicks in automatically,yet when I try and start it on the fan it never warmed up,wierd eh?
Check the grill as well to see if theres a general bad connection etc.
My element went but I got a new one and fitted it myself in 15 minutes - total cost of the job, less than a tenner.
Cost for a call out £80 + Parts (and they wanted something like the same again for an element!)
The fan oven will use an element situated around the fan blade.
Conventional oven use's the grill and a bottom element for cooking.
For the original poster......Does the thermostat light come on when you switch on the fan oven ? If it does......and the fan definitely works , then 90% sure it'll be the circular element behind the oven back plate.
Just make sure the clock is set as most fan ovens won't operate unless the clock is set .
JK12
33
Apr 26, 2021 12:09 PM
