arb bush
Old Sep 22, 2010 | 09:59 AM
robreg5's Avatar
robreg5
Default arb bush
I am thinking that my arb bushes where the bar mounts to the front chassis legs are worn and are allowing the bar to flex too much and catch the downpipe when conering?? Im thinking this because when I jack the car up and take the weight off the bar, it is a good few mm clear of the downpipe. My question is that the original rubber bush has a slot cut in it so it can be prised over the bar into position, do the polly ones have the same design or do the have to be pushed on from the end of the bar meaning it has to be disconnected from the tca?? Any help much appreciated
Cheers Robbi
Old Sep 22, 2010 | 05:07 PM
ECOS95's Avatar
ECOS95
The Poly ARB bush doesn't have a split in it. The AR has to come off to fit them.
Old Sep 22, 2010 | 05:19 PM
graham c's Avatar
graham c
i,ve got some uprated end ones you should fit them as well
Old Sep 23, 2010 | 08:18 AM
robreg5's Avatar
robreg5
Thanx for the replies Looks like ill be taking the arb off the car then or just repalce the bushes with new standard ones with the split in them.
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
DavidK
Sep 27, 2015 02:55 PM
