Boost peaking and dropping
Old Sep 19, 2010 | 08:23 PM
original's Avatar
original
Default Boost peaking and dropping
S1 rs turbo running FRST engine with a T3.
car is peaking at 10psi then the needle drops right down and only holding 5psi. thought it was the actuator but i have a forge item and took it apart and its fine, has a blue spring fitted.
I have discovered some cracks in the rear housing of the turbo would these cause this kind of behavior?
I welded them up today but it doesnt appear to have made any difference?
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Marv888
Sep 26, 2015 03:44 PM
Russ Payne
Sep 25, 2015 08:29 PM
