hi can i take my abs of my 2wd cossy and still run a servo brake set up ? or should i get rid of the lot and run a bias box , its only for trackday use and not on the road ?
Yes the abs can be taken off, so it just uses the lecky pump to give "servo" assistance, or run a bias box as for track use, would probably be better.
