Any ford techs on today look in
My missus has a 57 plate ford fiesta 1.6 tdci done 31 thousand miles now when you run it on the motor way for a bit then come to a roundabout or that the gears are very stiff are they cable opetared ? & is this a common fault i will phone ford today as i think its still in warranty but just wanted a heads up cause i know what they can be like
Just checked on the dvla site its in warranty untill november i will call them shortly cant see it being a cable if its only getting tight when warm
Its still under warranty & its cable i work for a bmw / mini dealer its the same engine & box as the new mini cooperD & there is a problem with the nylon bush on the shift unit on the box that dosent lubricate itself causing stiff gears ford say they dont cover adjustments but will cover the shift unit
its 100% got cables,
fixed a few of these like this,
the prob will be the selector shaft on the gearbox,
dampness gets in and corrodes the shaft, quick clean up and alls good again,
if ford wont entertain you let me know, i'm goin to johnstone to get a van off eddie in next couple days, i'll swing by and sort it out,
only take 15mins
only take 15mins
borboyous
Aug 22, 2015 11:17 AM
Versus_Creations
20
Aug 8, 2015 10:22 AM
