diff viscous fluid?
Old Sep 17, 2010 | 11:36 PM
AiToR51's Avatar
AiToR51
Default diff viscous fluid?
Hi
I've a rear VLSD diff from a Sierra cosworth 4x4, but it's old, and works like an open diff....So I want to change the Viscous silicone...
I don't have the money to send it to England an get a professional rebuilt(I'm a student ). So I want to try to rebuilt it at home as I only have 120-130bhp on my sierra and not need a very tight diff
could you recomend me a website where I can buy this?
could be useful the silicone that RC cars use on their diffs?
thanks
Old Sep 19, 2010 | 12:49 PM
AiToR51's Avatar
AiToR51
I will use RC diff silicone oil with 500.000cps of viscosity...I will try it next mont...Then I will write here the results
Old Sep 19, 2010 | 07:46 PM
BIL N KEL's Avatar
BIL N KEL
just weld the diff up
Old Nov 18, 2010 | 10:49 AM
AiToR51's Avatar
AiToR51
I like how it goes, is good
stock diff:
http://www.youtube.com/watch?v=HVBMPkICJlo
LSD with RC diff silicone 500.000cps:
http://www.youtube.com/watch?v=tA8WAPIHqNw
But now, the diff is out the car, because I did some in a bad way...and probably a bolt inside the diff broke, and the case crashed...I have to dismount it in a weekend and check what happened
I use my car every day...so I think is not the best option for me , but it has to be good on track for drift
Old Nov 18, 2010 | 11:21 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Do you have any pics of how you changed the silicone fluid? very interested. Bad news about the failure.
Old Nov 18, 2010 | 11:22 AM
chaffe's Avatar
chaffe
Also where did you buy it? eBay?
Old Nov 18, 2010 | 11:50 AM
chaffe's Avatar
chaffe
found this on ebay; http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
Old Nov 18, 2010 | 02:49 PM
AiToR51's Avatar
AiToR51
I only have this pics:
I dismounted it, cleaned all discs, and remount using this silicone.
I don't know which is the correct viscosity...I only tried with 500.000 CPS
I bought it on this shop of my country 3 bottles, used 2 and a half
http://www.maxiracing.com/product_in...oducts_id=1107
Old Nov 18, 2010 | 07:47 PM
chaffe's Avatar
chaffe
cool, might have a go mate
Old Nov 15, 2012 | 04:20 PM
mecatech's Avatar
mecatech
500.000 dont be good
not more heavy than the OE.
you must more. 1 millions centistocke to have 60mkg to the diff
Old Nov 15, 2012 | 05:17 PM
AiToR51's Avatar
AiToR51
Ok thanks. I will have it in mind if I've to dismount the diff again. Do you know where can I buy the silicone oil of more than 1 millon cps you say?
Old Nov 15, 2012 | 05:31 PM
Thanasis's Avatar
Thanasis
how do you adjust the side bearing preload?also i have used 100000 two bottles and one 300000 with good results,don't tight very much the viscous because the planet gears are not too strong!so don't use up to 300000 silicone oil
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Adam Graham
Sep 6, 2015 06:04 AM
