bringing emissions down?
Old Sep 17, 2010 | 03:25 PM
m4tt274's Avatar
m4tt274
Default bringing emissions down?
the p100 failed its MOT on its emissions. limit is like 3.6 or something and its 5.5.
what could be causing this high emissions?
Old Sep 17, 2010 | 03:39 PM
chaffe's Avatar
chaffe
Turbocharging Technician
knackered lambda sensor posibly, or air temp/ coolant temp sensor maybe cooked, is the engine otherwise standard?
Old Sep 17, 2010 | 03:40 PM
chaffe's Avatar
chaffe
Or air mass sensor could be dodgey
Old Sep 17, 2010 | 06:54 PM
m4tt274's Avatar
m4tt274
nice observant tags?
glad someone found it funny
anyway yeah, it is otherwise standard. and the lambda sensors were just welded up on the engine i bought, but its passed for the last couple years until now.
il have a look into the sensors, its worth saying that the car has been sitting in the workshop for a few weeks.
Old Sep 17, 2010 | 07:04 PM
Big-Dan's Avatar
Big-Dan
Just give it a good thrashing before you take it back in, seemed to do the trick for my car.
Big-Dan.
Old Sep 17, 2010 | 07:10 PM
vaughant's Avatar
vaughant
What engine fella?could be an electric pot somewhere to adjust the co2?
Old Sep 17, 2010 | 07:15 PM
m4tt274's Avatar
m4tt274
24v cos.
looked on the back of the ECU and there isnt that white screw thing that the 4x4 YB cossys have
Old Sep 17, 2010 | 08:27 PM
jamie's's Avatar
jamie's
if it doesn't have any lambda sensors on it the fueling will never be right,
try giving it a good kicking, failing that just square the guy up if thats all thats wrong
Old Sep 17, 2010 | 09:11 PM
vaughant's Avatar
vaughant
Sounds about right to me,no amount of adjustment would bring that in,although ill check the autodata to see what's what.
Old Sep 17, 2010 | 09:14 PM
BM08's Avatar
BM08
Did you take the car for a good run before the MOT?
Rsmat
89
Oct 12, 2015 07:50 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
atm
Sep 7, 2015 05:39 PM
borboyous
Aug 22, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
