rear diff???
Old Sep 16, 2010 | 06:30 PM
adam escort cosworth's Avatar
Default rear diff???
doing a 2wd conversion on my escos, brought a 2wd diff with 100 mm lobros, but the driveshafts and stub axles are 108mm witch means the driveshafts wont bolt to the diff flanges!!!!! where can i get 108mm flanges for the diff???? or what can i do????
Old Sep 16, 2010 | 07:32 PM
Turbosimpsons's Avatar
Turbosimpsons
it's easier to get the rest on the 2wd set up, or leave your 7" diff in. depends what power your running
Old Sep 16, 2010 | 07:39 PM
its a 2wd diff but its got the smaller lorbos 100mm?? the shafts are 2wd too with 108mm lorbos!!! im confused!!
Old Sep 16, 2010 | 07:45 PM
robrs2's Avatar
robrs2
You have got a Granada cossie diff if its an lsd with 100mm flanges.
You can either fir some 108mm ones from a 2wd saff diff or use the 4x4 7" shafts.
Old Sep 16, 2010 | 07:50 PM
it came out of a saph apparantly?? will it take 400 bhp
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Fezman1
Sep 7, 2015 09:34 PM
