should you run in a turbo?
Old Sep 16, 2010 | 05:03 PM
liamford's Avatar
liamford
Default should you run in a turbo?
does a re-coned turbo need running in? or can you just set boot to 1.5bar and away to go? cheers
Old Sep 16, 2010 | 05:22 PM
grcossie's Avatar
grcossie
Check your oil feed, before you connectit to turbo, and if its ok, then turmn up the boost, no problem
Old Sep 20, 2010 | 04:35 PM
Dave Hewy's Avatar
Dave Hewy
When i had mine refurbed they told me to take it easy for the 1st 20 miles or so, anyway i kept it under 4k for about 5 minutes then nailed it and its still going strong 2 years later.
Old Sep 20, 2010 | 06:00 PM
ECOS95's Avatar
ECOS95
Can't see why you would, if its been built correctly they should test it before it gets sent back. As said just make sure its getting a good oil supply.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
