escort diesel compression
Old Sep 16, 2010 | 12:40 PM
Austin101's Avatar
Austin101
Your talkin sh** now
Default escort diesel compression
My 98 escort is down on compression. 19 bar and it should be between 28 to 34 bar. Valves or piston rings? Any help would be great-full
Old Sep 16, 2010 | 12:41 PM
chaffe's Avatar
chaffe
Turbocharging Technician
maybe needs the valve shims re set, i take it that its a chore to start? take off the rocker cover and check the clearance
Old Sep 16, 2010 | 12:57 PM
Austin101's Avatar
Austin101
Valve clearance ok.Yea very slow to start in the morning
Old Sep 16, 2010 | 05:16 PM
chaffe's Avatar
chaffe
ok when cold? does it wind quick or slow? are the heater plugs all good? and is there an air leak in the diesel system?
Old Sep 16, 2010 | 05:33 PM
Austin101's Avatar
Austin101
Slow when cold,change the heater plugs,new filter housing and new pipes.Air leak in the fuel system would have nothing to do with it being down in compression?
Old Sep 17, 2010 | 10:35 AM
chaffe's Avatar
chaffe
if it winds slow because the starter or battery is cooked then it will be down on compression and sluggish to start.
Old Sep 17, 2010 | 12:46 PM
Austin101's Avatar
Austin101
Very good point,I'm going to screw out the pump and run it on the green stuff.Its not worth stripping the engine anyway.Going to try a new battery too
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
dombanks
Sep 21, 2015 08:38 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
Bighandsuk
Sep 2, 2015 05:23 PM
