I wana turn my 91 xr3i efi into efi turbo
Done this conversion to my 500se cabriolet.U need a fiesta turbo engine and ECU map sensor and fuel mixture pot . if u use a OFAC ECU its easy as it plugs straght in. with a OFAB u need to swop round some wires on the ECU plug and the map sensor wiring and plug is different. id use a escort t3 turbo as it fits the escort exhaust but u need to make the oil return pipe. put on a bleed valve on do away with the amnal valve as the xr3i dont have the wireing for it. hope this helps.
do u mean a escort rs turbo engine? u really need a fiesta rs turbo engine or its involved as u need adapter plate to fit the efi manifold and the escort rs turbo engine has no crank sensor.
would you take the time and tell me if this will work have a look at this listing on ebay and could you tell me wat i would need if i was to fit this engine here is the item number 230525232435
cheers carl
cheers carl
like i said the easy way is get a fiesta turbo engine and sensors a OFAC ECU a T3 turbo from a escort rs turbo. its easy
he says its in a cab, and if u go on his other items there is the cab for sale and the engine is still in it as an unfinished project.
why dont you ring up and ask if you can buy the whole lot then still be able to drive the xr3 around while building the rs cab project.
the escort fuel injection system is old unreliable and crap, stick with the newer efi mate, no dodgy fuel metering heads to rely on and its a nice straightforward swap. otherwise you will need the mfi fuel tank, fuel pump, loom, e.t.c....
ive just bought an engine with gearbox and everything else i need to do this conversion the engine is a sierra rebored to a 1900 with forged pistons con rods and strenghted crank shaft and loads of other mods ive got the recipets with engine toting up to nearlly 7k and the valuation sheet for the car the engine come out of
Matt Baxter
Sep 16, 2015 08:30 PM
The Underdog
29
Sep 7, 2015 09:49 PM
marky_g
Aug 15, 2015 10:43 AM
