rhd light
Old Sep 15, 2010 | 06:59 PM
john_d's Avatar
john_d
Default rhd light
ive got a set of lights on the cheap, the seller said he thought they were from rhd car (hence the price), are there any markings to show if a light is left or right hand drive? i can see "HR", are these anything?
Old Sep 16, 2010 | 07:58 AM
If you look at the lens most likely if they are rhd lights there will be a section that forms the kick up left part, this will be on the left hand side of the light as you sit in the car, right hand side as you face the light.
Most lhd use flat dip with no kick up so don't have this section, even thoiugh if they did would be on opposite side, just have a look around a few cars with normal style lights ie not the later style projector ones as light form is done inside these.
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
