99 Escort Van 1.8 non-turbo - Wont start...help!
Old Sep 15, 2010 | 05:51 PM
jg109135's Avatar
jg109135
Exclamation 99 Escort Van 1.8 non-turbo - Wont start...help!
Van was having trouble starting in the mornings, but then ran fine all day no worries.
Changed the glow plugs and the feed wire/bus bar connecting them was rotten, so replaced that also.
Conected it all back up, but now the engine wont start at all...
Battery is fine, relay clicks, all conections are clean, engine turns over but wont fire. Tried the fuel primer incase air got in...
Was trying to save a bit of cash by doing a DIY job, my knowledge of engine mechanics is limited though, I've just been reading up/learning from other threads on here...
Have no clue why its not working, any advice/help greatly appreciated!
Cheers now,
Old Sep 15, 2010 | 06:44 PM
Austin101's Avatar
Austin101
Your talkin sh** now
I went through the same thing.Right first of all when turning over the engine does the immo light flash under the clock if not open the injectors"17 spanner" and turn over the engine and see if you get any diesel.You be a pro at engines when you finished with the van.
Old Sep 16, 2010 | 12:41 PM
jg109135's Avatar
jg109135
Cheers mate, but I sorted it. The Glow Plug Fuse had gone. Thanks for the help though.
Old Sep 17, 2010 | 02:20 PM
james09's Avatar
james09
im aveing problems theres no dash lights comeing on the dash iv put new battery in theres nothing no lights at all anyone can help me cheers james
Old Sep 17, 2010 | 06:09 PM
Austin101's Avatar
Austin101
Had you dash lights before you put in the battery?Will the van start without the dash lights.Check all fuses. A real head scratcher hay
Old Sep 19, 2010 | 06:35 PM
jg109135's Avatar
jg109135
James, I've just had a simillar prob, my dash and side lights were out, fuse fine, apparently its a comon thing with escorts and the whole multifunction switch (indicator stalks) need replacing (£20 from breakers) just done mine and the side lights/dash lights are working again.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
jonjg
Sep 1, 2015 03:46 PM
Mxkid
Aug 31, 2015 10:02 PM
Vincereese
Aug 18, 2015 03:57 PM
