HELP with my escort 1.8si
Old Sep 14, 2010 | 08:12 PM
blighty88's Avatar
blighty88
Default HELP with my escort 1.8si
hi have a escort 1.8si that has few bits wrong with it, my reverse lights dont work ive replaced bulbs but still nothing, when i indicate left it flashes really dull and the brake light flashes with it sometime indicator flashes really fast when use brake, the hot heating doesnt work and makes strange sound when blowing also the revs go up and down and sometims even cuts out, if any one could help me with these small amount of probs lol would be great thanx
Old Sep 14, 2010 | 08:24 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Reverse lights will probs be the switch on the gearbox. The dodgy lights points to an earth problem, check the connections for corrosion. The ISCV is probs the culrprit for it cutting out.
No idea about the fan noises, but if it's blowing cold it sounds like it's air locked, a blocked heater matrix, or a problem with the selector not actually selecting hot.
Old Sep 15, 2010 | 03:44 PM
Best thing to do to the rear lights is to get a new pair of the bulb holders if they pins are rusted where the connector goes or solder the wires direct to the power tracks on the bulb holder, this is what I do, the main problem is usually the earth, often just soldering/screwing a wire from the earth track of the bulb holder to the body works wonders, I usually use a light mounting stud with a ring terminal etc.
For the reverse lights check out the power at the switch itself on the gearbox with ignition on one wire of the two should be live, the other one of course leads to the lights, bridge these two and if the lights then work(assuming you do have a correct live on one wire) then it is a switch problem.
The idle speed can most likely be sorted by cleaning the idle speed control valve.
The sound from the blower could be either the bearing is noisy, will still last years normally or it could have leave sin it if someone has left out the pollen filter.
For the heat issue is it just the heater or is the engine running cold ?, if engine as well change the thermostat, if just heater check first the bowden(cable) from the dial to the heater box in case it is out of adjustment, or popped off, some do sometimes.
Old Sep 15, 2010 | 06:01 PM
blighty88's Avatar
blighty88
thanx, the engine runs hot and seems to be alright its just the heater it blows out cold but not hot, do you know where the heater box is located and how is the best way to bridge wires??
Old Sep 15, 2010 | 06:58 PM
To bridge the wires just use a old piece of wire, strip 1/4" insulation from each end and jam in the plug.
The heater is like dead centre behind the controls, if you get down in the drivers footwell you should see the cable that moves the flap, and the flap on the side of the large plastic heater box, make sure this is getting full movement in the hot position, if not loosen the philips screw and move cable along slightly so the flap cam move full travel, has it had a recent matrix ?, maybe it wasn't put back very well, some dodgy people when selling cars bypass the matrix(if leaking) so this would produce no heat.
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
