focus 1.8 tdci egr valve cleaning
Old Sep 14, 2010 | 06:12 PM
focus111's Avatar
focus111
Wink focus 1.8 tdci egr valve cleaning
hello every body , i'm new in this forum , i'm owner of ford focus 1.8 tdci (2009) duratorq , i'm experiencing some troublshootings , like engine knocks onacceleration around 2000 rpm with some fume and loss of performance so ,l'm thinking about cleanind the EGR valve ...so if somme one can help me to extract this valave , i'll be very gratful ...many thanks
Old Sep 14, 2010 | 06:30 PM
B19 JUB's Avatar
B19 JUB
complete manifold off im afraid which is intergrated with exhaust manifold ie turbo too.if its 2009 model why dont u take it into your dealer to have it looked at under warranty
Old Sep 15, 2010 | 02:21 PM
focus111's Avatar
focus111
hi B19 ,thanks for your message , yes i do have warranty on my cus till december , i've took it to ford service last week , i think they had done only pcu update , but the probleme back after few miles ...
Old Oct 4, 2010 | 02:50 PM
Archibald's Avatar
Archibald
In 09 models, the EGR is detachable and does not require manifold removal (real pain as the exhaust has to go first then intake). I don’t have too much experience with this one but the main thing is that it needs a proper cleaning not just spraying with carb cleaner.
More importantly, you have to check whether it’s the EGR that’s causing problems. Did you check fault codes? Frozen EGR is usually shown as EML light on.
Old Oct 4, 2010 | 06:30 PM
focus111's Avatar
focus111
hi , i don't have any code ..but according to ford mecanics ,they have to change the injectors and then the EGR manifold..
Old Oct 4, 2010 | 07:17 PM
Archibald's Avatar
Archibald
And then DMF... Standard mechanics explanation for their lack of knowledge about 1.8 tdci.
I can help you but you would have to get codes. You can try the dials trick - press the dials reset button while turning ignition on. It should be explained on the forum how to get codes.
Old Oct 4, 2010 | 07:27 PM
focus111's Avatar
focus111
hi ,archibald , i hugely apreciate your help...please where can i find the dials reset button ??? thanks a lot
Old Oct 4, 2010 | 07:33 PM
Archibald's Avatar
Archibald
MKI - day trip reset button (next to the mileage display)
MKII - day trip reset button - indicator stalk.
Press it and turn ignition on holding it. Hold it for a 2-3 seconds and release it. There will be a new sign on your mileage display. Keep pressing reset button till you get to one with "DTC" - read codes is you can (4 digit).
BTW - where are you from?
Old Oct 4, 2010 | 07:37 PM
focus111's Avatar
focus111
yes ,i'm from algeria ,...i think i do not have any button ;my focus is 2009...any way i go down to the garage to verify just 5 minutes
Old Oct 4, 2010 | 07:54 PM
Archibald's Avatar
Archibald
Indicator stalk - check the tip of it. There should be a button there.
Old Oct 4, 2010 | 08:06 PM
focus111's Avatar
focus111
hi ARCHIBALD i've found the test so : " DTC 00 # none " like this
Old Oct 5, 2010 | 11:23 AM
Archibald's Avatar
Archibald
So no fault codes - I would suspect it's not an EGR valve, but you can always clean it and check if there's any difference.
Old Oct 5, 2010 | 08:03 PM
focus111's Avatar
focus111
hi ?YES I THINK SO ; i think there is probleme with the injectors because there is a gray smoke at 2000 rpm and somme knocks ???... but how can extreact the EGR i can give you somme pics ok my duratorq 1.8TDCI
Old Oct 6, 2010 | 08:50 AM
Archibald's Avatar
Archibald
Please send the photos and I will show you how to undo it. It's quite easy on yours.
Injectors on your 09 tdci are made by Siemens and I have not seen them going before.
Knowcking noice can be a DMF which even now is crap...but even more expensive crap than old ones.
Old Oct 6, 2010 | 05:56 PM
focus111's Avatar
focus111
hi archi , but it bit dificult to send photos on this web , it needs url adresse ...to u have email adresse?
Old Oct 6, 2010 | 08:01 PM
Archibald's Avatar
Archibald
Post it here
www.imageshack.us and paste link for forum
Old Oct 6, 2010 | 08:16 PM
focus111's Avatar
focus111
Old Oct 6, 2010 | 08:17 PM
focus111's Avatar
focus111
look just before
Old Oct 6, 2010 | 08:19 PM
focus111's Avatar
focus111
http://img440.imageshack.us/i/18092010630.jpg
http://img18.imageshack.us/i/18092010636.jpg
http://img695.imageshack.us/i/18092010635.jpg
Old Oct 7, 2010 | 10:13 AM
Archibald's Avatar
Archibald
EGR body itself is a part of the intake manifold and as such cannot be completely removed, but as you see on photos, the valve can be removed, by undoing 4 black bolts (there are 3 on the first photo).
Clean the valve and clean the body.
Old Oct 7, 2010 | 04:35 PM
focus111's Avatar
focus111
hi ...yes i think the valve is incorporated in the manifold ...but when you remove the 4 bolts you find only a rotating spare no valve look at this photo:
http://www.forum-auto.com/pole-techn...ujet539087.htm
Old Oct 9, 2010 | 08:52 AM
Archibald's Avatar
Archibald
Try to pull it.
Old Jan 6, 2013 | 08:20 PM
bananz's Avatar
bananz
Hi. Having trouble locating EGR in 2005 focus 1.8 tdci! Disconnected the electrical part and removed 4 bolts to reveal brass cork screw type thing which is reluctant to come out. Should I persist in trying to remove this or is there another way in???
As you can probably tell I'm not too car savvy, so any explanation will have to be blow by blow please.
Car is emitting clouds of white smoke on start up and is reluctant to start on cold days - got someone to check for fault codes and it threw up EGR. After taking things apart and putting together again, fault code has changed to glow plug!! and now have the engine management light on and car is in limp mode. What is going on???? Can anyone out there help??
Old Jan 14, 2013 | 09:53 PM
mearnsa4's Avatar
mearnsa4
Bet you feel whole lot betterer 2day, lol!
Old Jan 15, 2013 | 11:15 AM
bananz's Avatar
bananz
Indeed I do!
Old Jan 27, 2017 | 07:20 PM
FastLife91's Avatar
FastLife91
Hi
Does one need to have access to work under the car to complete this job or is it all done from above ?
Is the turbo easily accessible once the manifold is removed or are other parts preventing it from being removed ?
I have a 2006 mk2 ford focus sport 1.8 TDCI, I think it is the same engine you have ?
thanks
CossieRich
30
Sep 8, 2015 10:08 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
