Cosworth YB 205 Spark plug Problem help needed
Old Sep 14, 2010 | 12:13 AM
NTG's Avatar
NTG
Default Cosworth YB 205 Spark plug Problem help needed
Hello, my N/A YB cosworth engine blow out number three plug, the plugs have reducer bushes in the head so the plugs are 10mm not the 13mm, the plug came out with reducer attached.
Now is it posible to to helicoil or timesert the sparkplug hole without removing the head?? if so have you any suggestions how to catch the swarf? would like to do in situ or would i just be better off removing the head. any advice would be great thanks
Old Sep 14, 2010 | 06:21 AM
Imo remove the head, and give the bill to whoever did the bad job on the inserts for the smaller plugs.
j.hammond1
30
Oct 31, 2021 05:28 PM
Bobby9779
Aug 11, 2015 06:47 PM
Zoggon
Aug 10, 2015 10:39 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
adriansaleem
Aug 1, 2015 09:28 PM
