ECU Swap
Old Sep 13, 2010 | 08:35 AM
ryan2910's Avatar
ryan2910
Default ECU Swap
Hello there,
I am thinking about buying a chipped ECU from a friend for a MK 5 Fiesta Zetec S but my key will not work with his ECU, am I right in saying?. He is breaking the car so he is able to give me the key aswell. I am just wondering what work has to be done once I have the ECU and key, is it possible to swap the chips in the keys in any way?
Thanks
Old Sep 13, 2010 | 04:19 PM
martysmartie's Avatar
martysmartie
Yes the key will need to be paired with the ECU for PATS, in the key there should be a blue or similar coloured transponder, if you put this in your key this would work.
Martin
Old Sep 13, 2010 | 04:27 PM
RichieST's Avatar
RichieST
Tape his key to the ignition barrel, inside the plastic casing. This will fool the ecu into thinking you are inserting the correct key.
Just don't forget your immobiliser will be permanently disengaged!
Old Sep 13, 2010 | 05:15 PM
ryan2910's Avatar
ryan2910
How do you open up the key without damaging it? and is this the only part you have swap over? Also I dont have the large remote central locking key its the standard ford key black with the red patch does this make any difference?
Thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
cossie brad
Sep 29, 2015 02:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
grishenko45
Sep 9, 2015 12:58 PM
