timing via vernier pulley on a piper 285T2 ????
Old Jan 24, 2005 | 07:41 AM
220TC's Avatar
220TC
Default timing via vernier pulley on a piper 285T2 ????
Hi,
Do you 'advance' the cam timing on the pulley to make the cam come in earlier ?
Its on standard timing at the moment but it comes in really late, I am going to get my tuner to advance it 2 degrees, from peoples experience will this make a noticeable difference in the power delivery ?
cheers, Duncan
Old Jan 24, 2005 | 08:35 AM
Rallyesport's Avatar
Rallyesport
You have to measure when the first inlet valve opens to set the timing correctly. You do this with a dial gauge. It's very important that you correctly set the specified timing to get the most out of your cam.
How you do this is explaind in the Burtonpower catalouge.
Old Jan 24, 2005 | 09:17 AM
220TC's Avatar
220TC
the cams allready fitted & timed in correctly its just its set to zero degrees on the vernier. So what I want to do is alter the timing slightly via the vernier to move the powerband, that all.
As above, from peoples experience, what changes have you made to the vernier and did it make any noticable difference ?
cheers, Duncan
Old Jan 24, 2005 | 10:17 AM
phil21's Avatar
phil21
this is an interest to me to, not got a v pulley yet but after one. from what i have been told u advance the cam but only 2 degreas max,then take it for a test down the road.
Old Jan 24, 2005 | 12:47 PM
220TC's Avatar
220TC
I wouldnt attempt it yourself mate unless you really know what youre doing, remember the ignition timing & fueling have to be set up as well. Mines going to a local tuner so he can check it all on the rollers.
anyone ?
cheers, Duncan
jonfoc
16
Sep 11, 2018 05:35 PM
slammedorion
15
Nov 1, 2015 07:17 PM
xrmalin
Sep 13, 2015 06:52 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
hopper350
Sep 4, 2015 12:53 AM
